Author Topic: Flash drive and RCD510  (Read 1554 times)
AA
« on: February 14, 2013, 05:33:08 pm »
 :happy2:What is the largest capacity flash drive I can use with the RCD510
Offline paulw123
  • -Receive: 47
Re: Flash drive and RCD510
« Reply #1 on: February 14, 2013, 05:48:39 pm »
er...2gb sd card i think i've read somewhere.
Offline Falky
  • GTi Ed30
« Reply #2 on: February 14, 2013, 05:58:24 pm »
as far as I know there isnt a limit with USB, but with SD its 2GB and SDHC its 32GB
I use SD in my HU and it works brilliantly
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: February 14, 2013, 10:29:20 pm »
Have used the same SDHC 32GB in both a RCD510 and RNS510 with out any issues
Offline MrDo
« Reply #4 on: February 14, 2013, 11:11:28 pm »
My RCD 510 (non SatNav) reads a 32GB SDHC fine. Under £20 to buy a class 10 card (fast read and write).
SatNav enabled RNS 510 depends on firmware version to read SDHC.
http://www.my-gti.com/719/differences-between-the-volkswagen-rcd-210-rcd-310-rns-310-rcd-510-and-the-rns-510
Offline paulw123
  • -Receive: 47
« Reply #5 on: February 15, 2013, 11:24:39 am »
Do you need any special folder name structure on SD card, or just copy mp3's into a single root folder?
Would albums in different folders work?
Offline MrDo
« Reply #6 on: February 15, 2013, 12:55:58 pm »
Different folders works best when you have lots of albums. You can navigate up and down the folder tree. Keep the folder names as short as you can, I think approx 20 characters is the max displayed.
Offline wacky
  • -Given: 56
« Reply #7 on: February 15, 2013, 02:13:44 pm »
I use a 32gb SDHC with my RCD510, dont need it for albums as i have an ipod dock in the centre console so i use the memory card for mixes, i copy straight from dropbox onto the card no other folders required.
