Author Topic: RNS 510 Button illumination has stopped working.  (Read 2932 times)
Offline ell.s
« on: February 15, 2013, 12:28:51 am »
Got in my car tonight and noticed the RNS 510s buttons weren't illuminated so I tried turning the lights back off and on keys in and our and it got me nowhere is thus a common fault with an easy fix or us my unit buggered?
« Last Edit: March 03, 2013, 05:48:27 pm by ell.s »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RNS 510 Burton illumination has stopped working.
« Reply #1 on: February 15, 2013, 01:10:58 am »
do the buttons work?
have you recently updated the firmware?
Cluster and Key coding
Location Great Yarmouth
Offline ell.s
« Reply #2 on: February 15, 2013, 05:36:21 am »
Yes everything seems to work, no not recently probably about 3 months ago but all has been fine till now.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: February 15, 2013, 05:32:06 pm »
the car sends a signal to switch the illumination Terninal 58D
Does your RNS have Test / Development mode (press and hold SETUP for about 30 seconds)
I think if you go into there and select CAN it should show you if the RNS is receiving the signal
Offline V6nutter
  • -Given: 17
Re: RNS 510 Button illumination has stopped working.
« Reply #4 on: November 27, 2016, 08:48:57 am »
Hi - did you get this issue resolved? Im having the same problem.
Offline V6nutter
  • -Given: 17
« Reply #5 on: November 27, 2016, 09:39:05 am »
Results from CAN menu
Speed Signal 0km/h
CAN Reversing off
KL15 on
KL58 d 94%
S-Kontact on
Mute bit off
Analog mute off
Mute Value 0
Do these look ok?
