Author Topic: dash fault now non start  (Read 2552 times)
Offline tomolambo
  • points mean prizes
« on: February 16, 2013, 05:58:23 pm »
i have a mojor fault with my gti
it started with when turning left, both dials would drop and all the warnings lights would come on once steering wheel was in straight ahead posistion would go off or turning right would be fine was only happening when turning left, this was hapening for a couple of hours then the air bag light stayed on constant but was still faulting when turning left
got the codes read cant rember the exact codes but were lost coms with instrument cluster an lost coms with air bag module
i have had the steering wheel module replaced with new module and still the fault is present
now the car is intermitant none starting aswell as old fault
does anyone have any ideas what could be at fault?
i am thinking cluter fault but dont want to just replace and still have fault
any ideas would be greatfull
cheers tom
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: dash fault now non start
« Reply #1 on: February 16, 2013, 06:24:20 pm »
you need a scan
Cluster and Key coding
Location Great Yarmouth
« Reply #2 on: February 16, 2013, 06:37:56 pm »
Where are you based?
Offline tomolambo
« Reply #3 on: February 16, 2013, 06:44:22 pm »
liverpool i have had it scanned jus cant rember wht the codes were
Offline tomolambo
« Reply #4 on: February 16, 2013, 06:58:57 pm »
049493- no communication with intrument cluster
           u0155-008- - itermittent
049412- no communication with cruise control module
           u0104- 008- - intermittent
« Reply #5 on: February 16, 2013, 07:47:07 pm »
I'll leave this to Eddie for advice.
Offline gman1986
« Reply #6 on: February 22, 2013, 05:04:55 pm »
Sounds like a damaged wiring loom. Have a good look under the steering column and visually inspect the wiring. Also check to make sure that any interior body earth straps are still connected and not damaged.
Has there been any recent modifications to the electrical system?
