Author Topic: Cruise control retrofitting. Is my control module compatible?  (Read 2387 times)
Offline andybon
« on: February 17, 2013, 04:08:25 pm »
Looking into getting cruise control retrofitted to my golf. Been looking but can't find any definite answers.
On my car I have the control module with part number 1KO 953 549 BC. Was wandering if this was compatible and if it was a straight forward fit, Or would I need to change it?
How hard can it be?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Cruise control retrofitting. Is my control module compatible?
« Reply #1 on: February 17, 2013, 04:32:03 pm »
http://www.mk5golfgti.co.uk/forum/index.php?topic=33605.20;wap2
Have a quick scan and see if its of any help.
Offline b19_brv
« Reply #2 on: February 17, 2013, 04:48:55 pm »
Hi mate,
Not sure if you got it sorted but looks like you got a midline control module which is compatible for cruise control.
Would be good to upgrade to a highline if you wanted to upgrade the steering wheel to a fully MFSW  :happy2:
Here's a link to see the specs of your module:
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Hope this helps matey
Offline andybon
« Reply #3 on: February 17, 2013, 04:51:37 pm »
I haven't, Its baffling me! Says on the ross tec site that it wont work, But people are saying it does and doesn't!
How hard can it be?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: February 17, 2013, 04:54:43 pm »
You can quote me on this (my tally is nearly 50 now)
BC controller does work with cruise, providing the HW SW is NOT 638
035, 036 and 636 are ok
The above is also applicable to other part numbers
The Ross-Tech info is also wrong when it comes to BS and CB modules
CB is a Highend
BS & CB do not support the G85 behind the slip ring
Cluster and Key coding
Location Great Yarmouth
Offline andybon
« Reply #5 on: February 17, 2013, 04:56:23 pm »
I took a pic of the sticker on the control module. I'll upload it now. All these numbers are confusing me!
How hard can it be?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #6 on: February 17, 2013, 04:56:52 pm »
Eddie to the rescue
Offline b19_brv
« Reply #7 on: February 17, 2013, 05:00:21 pm »
Variants:
Lowline: No additional Options/Features
Midline: Cruise Control, Board Computer
Highline: Cruise Control, Board Computer, Multi-Function Steering Wheel
1K0-953-549-BC    Type 2    SW 0070    Midline    Yes    -    #1
As above your module falls under midline which does support cruise control,
Shouldn't have any problems mate
Offline andybon
« Reply #8 on: February 17, 2013, 05:02:31 pm »
but if you look at the #1 it says it doesn't, Strange!
Heres a pic of the sticker on mine
How hard can it be?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: February 17, 2013, 05:03:16 pm »
That will be fine
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #10 on: February 17, 2013, 05:04:48 pm »
The HW is 036 which eddie says is ok?
Offline andybon
« Reply #11 on: February 17, 2013, 05:07:16 pm »
Sounds good to me, Thanks for clearing up the confusion!
A local specialist charges £150 to supply and fit this, Does  this seem a good price?
How hard can it be?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #12 on: February 17, 2013, 05:16:07 pm »
I would say its a bit expensive! The stalk is £50-£60
Offline andybon
« Reply #13 on: February 17, 2013, 05:19:02 pm »
Think this is something i'd rather someone else do, As I don't fancy messing about taking the steering wheel off. Done it before with a previous car and it was a pain to get the steering wheel straight again after it!
How hard can it be?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: February 17, 2013, 05:20:05 pm »
I Charge £90 for supply and fitting the stalk
If the wire is required that adds £20
