Author Topic: Idle speed and coldstart issues on Edition 30..Terraclean to resolve..  (Read 27417 times)
Re: Idle speed and coldstart issues on Edition 30..Terraclean to resolve..
« Reply #60 on: February 22, 2013, 03:56:51 pm »
So how does he do it on the TFSI Steve?
Saintsteve
« Reply #61 on: February 22, 2013, 04:00:11 pm »
Didn't ask but he says its not a problem. Will find out tomorrow I guess...   :happy2:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 247
« Reply #62 on: February 22, 2013, 04:03:14 pm »
Recon he disconnects the fuel line and insets their own line hooked up to the fancy machine  :popcornsoda:
« Reply #63 on: February 22, 2013, 04:03:59 pm »
How's that going to clean your inlet valves?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 247
« Reply #64 on: February 22, 2013, 04:07:47 pm »
It isn't  :stupid:
May clean your fuel lines, cylinder, exhaust valve and exhaust system though. They run the engine on their own fuel which has some magic cleaning power.
I wondered whether they could disconnect the MAF and run it on some form of inlet cleaner. Maybe that's the next revolution in direct injection cleaning. . .
Steve - may be worth a run on the rollers with your new map and clean fuel system?
Saintsteve
« Reply #65 on: February 22, 2013, 04:09:13 pm »
I'm not fussed about the valves Ian, my injector is my objective as I agree, if this goes on the fuel rail, then this will treat everything from the rail to the exhaust Cat.
If I didn't have this misfire then I wouldn't be trying this. But I now my valves aren't the issue as when warm, the car is fine .
We shall see. If I get better mpg after, and a better performing car,then it's money we'll spent. You can't have clean valves all the time.  :grin:
Offline chungster
« Reply #66 on: February 22, 2013, 04:10:50 pm »
If the injector is f00ked no cleaning will fix it!
It'll help ur high HC readings though potentially but yeah I can't see how it will clean the inlet valves as it DI bypasses that!
They claim on their site it works for DI though so lets see how Steve gets on
Saintsteve
« Reply #67 on: February 22, 2013, 04:20:30 pm »
The injector seems to be working ok 90% of the time :grin:
I'm looking foward to the results  :happy2:
Offline chungster
« Reply #68 on: February 22, 2013, 04:24:02 pm »
Yeah I thought that till all the lights came on
Just watch out for the EML mine didn't come on for a few weeks.
But I think it's inevitable unfortunately
Saintsteve
« Reply #69 on: February 22, 2013, 04:34:06 pm »
Either that or AKS changed an injector that might of been salvageable ?
No one knows that this Terraclean will or won't do, so it's a cheaper alternative to an expensive decoke , then it's worth a go.
Even a fuel mpg improvement will be worth it  :grin:
http://www.terraclean.co.uk/terraclean%20testamonials.html
« Last Edit: February 22, 2013, 04:35:53 pm by Saintsteve »
Offline chungster
« Reply #70 on: February 22, 2013, 05:00:14 pm »
Well the swap fixed the problem straight away. There wasn't much build up the mani was off from what he can see.
Mine was probably a load more than u though. Was counting into the hundreds and thoughout the rev range
Saintsteve
« Reply #71 on: February 22, 2013, 08:06:14 pm »
With this Ian  :innocent:
http://terraclean.net/product.php?id=2
And with this..
http://terraclean.net/product.php?id=54
Hope this helps  :smiley:
« Last Edit: February 22, 2013, 08:40:13 pm by Saintsteve »
Saintsteve
« Reply #72 on: February 22, 2013, 08:34:41 pm »
I also read the R-tech Nick was looking at becoming a dealer.. Wonder if he has any feedback whether this works?
Offline Wild Bean
« Reply #73 on: February 22, 2013, 08:36:07 pm »
Something for you to follow Steve, if the guy replies tonight
http://www.ttforum.co.uk/forum/viewtopic.php?f=19&t=318942
Saintsteve
« Reply #74 on: February 22, 2013, 08:39:21 pm »
Will keep n eye  :happy2:
