Author Topic: Golf MK5 Door Stick  (Read 1620 times)
Offline Palooza
Golf MK5 Door Stick
« on: February 18, 2013, 06:14:54 pm »
I've just got a new mk5, and I love it! But I'm having an issue with the front passenger door. It doesn't open correctly, it like sticks, it's as thought it catches on something, like the rubber has stuck to the metal, but there isn't anything there.
I tried to record the problem but I don't think the video shows it very well but I'll link it anyway..
Anybody have any ideas? It happens from the inside and outside.
Offline doylebros
Re: Golf MK5 Door Stick
« Reply #1 on: February 18, 2013, 06:17:10 pm »
Offline Palooza
« Reply #2 on: February 18, 2013, 06:33:31 pm »
I thought door lock originally, but the door unlocks and locks fine, with the key and the button on the door :/
Offline doylebros
« Reply #3 on: February 18, 2013, 06:36:19 pm »
If you scan the car it will most likely show you the fault - I still go for the latch though.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: February 18, 2013, 06:45:58 pm »
first try lubricating it, use white lithium grease
failing that replace it
Cluster and Key coding
Location Great Yarmouth
Offline Palooza
« Reply #5 on: February 18, 2013, 07:09:52 pm »
I tried a bit of wd40, but that didn't help! But if your all confident it's the lock I'll just replace it!
Cheers for the help
