Author Topic: Having lean idle bank 1 problems  (Read 2380 times)
Offline Bainsy edition 30
« on: February 19, 2013, 09:37:48 am »
Hi I'm having lean idle bank 1 issues putting mil on.
Changed.fuel pump cam follower.
Fuel filter.
New O2 sensor.
Smoke tested no leaks.
Getting high fuel trims.could it be down to new neuspeed intake I fitted.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Having lean idle bank 1 problems
« Reply #1 on: February 19, 2013, 09:45:28 am »
Guessing you're stage 1 and just put a CAI filter on... sounds like you HPFP is struggling to meet the extra fueling needed for the extra air...
Diesel Daily Hack.
« Reply #2 on: February 19, 2013, 11:49:43 am »
I'm stage two mate.with full turbo miltek and neuspeed plus uprated oem diverter valve.had problem after fitting exhaust and intake but before remap.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: February 19, 2013, 03:03:07 pm »
Look for looseness in the new intake clamps first. Then check the mass air flow sensor. Find someone not experiencing the issue that will let you try theirs briefly. That will show whether or not to replace it.
If that's not it it is likely the pcv and maybe even coils.
« Last Edit: February 19, 2013, 03:10:28 pm by ROH ECHT »
« Reply #4 on: February 19, 2013, 04:28:09 pm »
Sorry forgot to say iv blocked pcv.and she's had new coils.im getting 254g/s on maf log does this sound right for stage 2.it tends to put mil up when I park car up hot then start up again when hot it's there.hot start
Offline mines a leon
« Reply #5 on: February 19, 2013, 04:35:38 pm »
You on Revo??
APR stage 3 Leon! Custom mapped! K04 Powaaahhh
With a willy waving 350bhp!
« Reply #6 on: February 19, 2013, 06:10:37 pm »
No mate hyperchips
« Reply #7 on: February 19, 2013, 07:12:01 pm »
Just took maf plug of and run car around town and long turm fuel trim is staying 9.2 with maf on its 24% and over.does that meen my mafs bad.
« Reply #8 on: February 19, 2013, 07:27:45 pm »
Could be but better be sure it's not the map itself causing  these issues...
« Reply #9 on: February 19, 2013, 08:07:55 pm »
It was doing this before I had map on car mate
« Reply #10 on: February 19, 2013, 10:06:25 pm »
I'm just the messenger here but any decent tuner would have sorted your issue before mapping the car.
« Reply #11 on: February 21, 2013, 11:29:57 am »
Without a doubt, running lean can be fixed by rescaling the MAF to deal with the adapted air flow!
Get yourself a proper tuner! Not just the cheapest!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4178ombbjud8jj8upkrato4hgn&/topic,19740.0.html
« Reply #12 on: February 21, 2013, 11:46:24 am »
Fuel trim should be +-10% from what i remember
