Author Topic: Bsh pcv mods?  (Read 1369 times)
Offline Itsagthing
Bsh pcv mods?
« on: February 19, 2013, 08:40:39 pm »
I have searched a little on this  but haven't  seem to find anything on them although I am a newbie. Does anyone on here not do the bsh pcv mod and catch tank for helping with the conspicuous valve clogging?
Re: Bsh pcv mods?
« Reply #1 on: February 19, 2013, 10:12:52 pm »
I think alot of folk just use the latest oem pcv.
As for myself, I use the bsh catch can setup in an effort to delay intake valve deposition of carbon.
Offline Itsagthing
Re: Bsh pcv mods?
« Reply #2 on: February 20, 2013, 02:45:35 am »
Ah ok cool. Think I may do the pcv bsh mod
Offline 56OctyVRS
  • -Receive: 72
Re: Bsh pcv mods?
« Reply #3 on: February 28, 2013, 10:33:24 am »
The catch cans do not work on the TFSi, as when under boost the excess pressure is vented via the rear tube which goes down into the turbo. This then goes back into the air intake and pulls through oil. So unless a catch can is fitted on that port they are pretty useless. The VW race cars don't use catch cans and have the OE PCV fitted. I have tried them all and the car ran far better with the PCV fitted.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Bsh pcv mods?
« Reply #4 on: February 28, 2013, 11:53:34 am »
Also, you will always get some oil through the tubo seals anyway  :sad1:
VRSAlex mentioned again the other day how a catch can has done nothing to help keep his valves clean  :grin:
Offline Itsagthing
Re: Bsh pcv mods?
« Reply #5 on: March 01, 2013, 06:12:01 am »
Hmmm interesting read guys ants for the advice, I have seen a few guys now swear blind that the catch can helps on the Gti, more so Ryan from regal is dead keen on fitting one to every car. Maybe you guys are right though and ill get the latest pcv revamp if not already fitted.cheers
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Bsh pcv mods?
« Reply #6 on: March 01, 2013, 07:06:57 am »
Here's a post from Alex saying he had to re-clean his inlet valves after only 10k miles WITH a catch can fitted. Proof enough that they don't work:
http://www.mk5golfgti.co.uk/forum/index.php/topic,61952.msg695354.html#msg695354
Offline Itsagthing
Re: Bsh pcv mods?
« Reply #7 on: March 02, 2013, 04:27:04 am »
Cheers bro helps a lot.
