Author Topic: Steering Angle Sensor  (Read 1822 times)
Offline Carson_A
« on: February 20, 2013, 09:25:46 pm »
Well lads,
Having a problem with getting the car through the mot at the minute. The car has the power steering light on the dashboard all the time. When plugged into the VAGCOM it is saying that the steering angle sensor needs to be reset. However, when we try to do the basic settings it "forgets" the basic settings about 3 seconds after.
I would like to clarify that the car has already had a new steering rack.
Has anyone had this problem and can shine a light on what the issue may be?
Thanks in advance!
Offline Dannyboy88
Re: Steering Angle Sensor
« Reply #1 on: February 20, 2013, 09:29:30 pm »
Go for a short drive then pull up with the wheels straight then full lock to the left hold it there 5 seconds then full lock to the right for 5 seconds then set the wheels straight again and that should do it, if not try it afew times, steering angle sensor fault code can't be cleared with vagcom you have to do the full lock thing, I found this out at the weekend when I'd fitted cruise control.
« Last Edit: February 20, 2013, 09:31:21 pm by Dannyboy88 »
Offline Carson_A
« Reply #2 on: February 20, 2013, 10:04:41 pm »
Already done that dude :(
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: February 20, 2013, 10:11:34 pm »
Did you do it how is says, sometimes it takes a few goes  :happy2:
A quick search on the forum should help, if someone dosen't come along to point you in the right direction  :happy2:
http://wiki.ross-tech.com/wiki/index.php/00778
try that  :happy2:
Silver is the way !
