Poll
boot pop mod, cant open unless facing uphill, lots of people got it but lots of mixed results. Please vote
pops fine, works fine, even when on a slight downward hill ( without mk6 rear camera fitted )
2 (22.2%)
doesnt work unless facing slightly UPHILL ( without mk6 rear camera fitted )
2 (22.2%)
works fine even when on a slight downward hill ( I HAVE REAR MK6 CAMERA UNIT FITTED )
3 (33.3%)
doesnt work unless facing slightly uphill ( I HAVE REAR MK6 CAMERA FITTED )
2 (22.2%)
Total Members Voted: 9
Author Topic: boot pop, does it actually work, with or without mk6 camera, please vote  (Read 1509 times)
Offline scottm72
I cannot get this mod to work unless facing uphill,
ball joints all greased up,
installed correctly,
please only vote if YOU ACTUALLY HAVE THIS MOD
I know the mk6 rvc adds weight so that is the reason i have set the voting up in this way
feel free to add any comments, i am currently trying to see if any stronger rubber stoppers are out there, any help appreciated
ps,, with the new struts in place and opening and closing the boot daily on my mk6 i gotta remember and shut the wifes mk4 boot a bit softer, nearly shattered the back window on a few occasions with the tail being sooo light  :signLOL:
« Last Edit: February 22, 2013, 09:50:26 pm by scottm72 »
Offline skard
  • -Receive: 245
Re: boot pop, does it actually work, with or without mk6 camera, please vote
« Reply #1 on: February 20, 2013, 11:57:40 pm »
Worked more often on my GT with same hardware. The GTI spoiler maybe adds extra weight.
Not fully opening has always been an issue with this mod, especially in winter.
Offline SI-R32
  • -Receive: 126
« Reply #2 on: February 21, 2013, 05:13:54 am »
Works fine for me Scott, with Rvc and quite a few extra wires and aerial module also added to lid, in fact i've noticed its got much better over time as it would always work when hot and on any incline, in the cold it was hit and miss but its freezing at the mo and always flips up for me.
Si
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #3 on: February 21, 2013, 06:01:44 am »
After I greased everything the other week, when the temps were higher, the mod worked great, now were having low singles again, it doesn't work at all.
To those that have this working even in these conditions, how many notches on the bump stops are you using?
Offline scottm72
« Reply #4 on: February 21, 2013, 11:57:55 am »
thanks for the input guys interesting reading, hopefully with at least a few dozen votes etc it will be clearer regarding this mod
Offline scottm72
« Reply #5 on: February 21, 2013, 11:05:47 pm »
 :driver:
Offline scottm72
« Reply #6 on: February 22, 2013, 09:54:10 pm »
Hey my poll has been VIOLATED by a boost troll lover  :rolleye: :rolleye: :rolleye:
Maybe it was one of his biatches  :congrats:
« Reply #7 on: February 22, 2013, 09:59:10 pm »
Wasn't me! before you go sending me PM's.  :chicken:
Offline scottm72
« Reply #8 on: February 23, 2013, 12:48:31 am »
time of the month is it  :chicken:
Offline scottm72
« Reply #9 on: February 24, 2013, 11:53:39 pm »
bump
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: February 24, 2013, 11:58:46 pm »
I fitted the boot pop to Banham's Gti
worked first time no problem, even without grease
I take it the scirocco bumpers have been released, so they spring back out when pushed in?
Cluster and Key coding
Location Great Yarmouth
Offline scottm72
« Reply #11 on: February 25, 2013, 12:07:16 am »
any ideas eddie if a different set of the rubber bumpers are available out there, im thinking something with more compression than the normal boot pop ones we have fitted, im not sure if the actual fitting to the car size is generic or differs from car to car.
i just cant get the thing to pop enough unless i am facing downhill, even slightly downhill wont work  :ashamed:
Offline chrisr763
  • -Receive: 62
« Reply #12 on: February 25, 2013, 12:09:56 am »
Scott, are you using the scirocco poppers?
« Last Edit: February 25, 2013, 12:20:13 am by chrisr763 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: February 25, 2013, 12:16:03 am »
have they been released?
they should be around 50 - 60mm and compress to 30 - 40mm
Offline chrisr763
  • -Receive: 62
« Reply #14 on: February 25, 2013, 12:20:34 am »
Scirocco (Sprung) Pump stops          1K8 827 761 D
