Author Topic: Removing side skirts  (Read 1446 times)
Offline alexmccabe
    • Alex McCabe
« on: February 23, 2013, 12:30:22 pm »
I'm getting my side-skirts painted next week, and today is the only day that I can remove them. I have found a guide on how to do it, and it looks fairly simple but I was just wondering if there was anything I should be weary of, or be careful with?
MK5 Golf GTi 197BHP Tornado Red
Offline chowgar
Re: Removing side skirts
« Reply #1 on: February 23, 2013, 12:53:11 pm »
Get a blade and slice the double sided tape as you take the skirt off... Otherwise you may snap the hanger...
The tape is a killer to get off and you'll need maybe a toffee wheel or panel solvent to get the residue off... Unless you are really lucky and the tape comes off easy (unlikely tbh). Getting back on is easy...
Offline alexmccabe
    • Alex McCabe
« Reply #2 on: February 23, 2013, 01:12:50 pm »
Alright thanks. Nothing is as easy as it should be, is it?
Offline alexmccabe
    • Alex McCabe
« Reply #3 on: February 23, 2013, 03:18:25 pm »
Proving that nothing is as easy as it should be, the one side has a rounded torx screw in it. Cannot get it undone. How do I deal with this? Any help is appreciated.
Offline MattR32T
« Reply #4 on: February 23, 2013, 03:31:24 pm »
Put a slot in it with a dremel and remove with a screw driver. The adhesive is better attacked with a heat gun and then 95% will scrape off, finish up with thinners. Good luck.....
Offline alexmccabe
    • Alex McCabe
« Reply #5 on: February 23, 2013, 04:09:40 pm »
Thank you, I don't have a dremel but I used a junior hack saw to cut a hole then luckily a T25 fit when jammed in. Worked a treat. Will try to remove the sticky crap tomorrow.
