Author Topic: Another vote for checking your DV!  (Read 7167 times)
Offline Richie_101
« on: February 23, 2013, 07:22:30 pm »
I changed my DV today, and am I glad I did... the boost is back!  :laugh:
I bought a standard GTI about a month ago which 'whistled' when accelerating, so I was pretty sure that the DV seal was shot. Measured on any scale, I'm no car mechanic, so thanks to Lee (nc35) for posting his write up a few years ago.
Here's the bones of it...
Fitting is quite easy.  Remove OSF wheel and front of the wheel arch liner - the bit with the vent for the brakes (you will know it when you see it).
Once removed the DV is just behind the inner wing.  The photograph in the first post will help you recognise the location.  It is fastened on by three 5mm alan bolts.  They are a little awkward to get to but not that bad.  I have a Halfords Micro Pro socket set - about £30 if not in one of the 1/2 price sales.  It is the best bit of kit I have ever bought, for just over a tenner and the instant replacement of broken bits for the pro range can't be beaten.
The kit has all the adapters in it to remove the wheel arch liner and the alan bolts.
Use a bit of thread lock before refitting.
All in all took about one hour from start to finish.
Hope this helps.
I don't own any ramps/axle stands so this 'going in through the wheel arch' guide was perfect - I did borrow a trolley jack though, rather than put my faith in the scissor jack.  :happy2: The whole thing went pretty smoothly, but I'll just add a couple of extra things which may help someone else.
- If you open the bonnet, enough light will get through so you don't need a lamp. I did have a lamp, but once my hands were in there casting shadows, it didn't really add anything.
- There's about a million nooks and crannies under the DV so spread a cloth out under the DV and cover the whole lot and if (when!) you drop something it just lands on the cloth.
- There isn't a lot of space, so if you aren't familiar with how the clip for the DV wiring works, look at one in the engine bay first to see how they come apart. (There's one situated between the fusebox and the headlight).
- Like Lee, I used a 5mm allen key socket on a small ratchet (1/4") for the top bolt, but found it easier to do the lower two with a standard 5mm allen key. You can get one hand each side of the suspension strut which helps.
My car is a 55 plate with 99k on the clock (AXX engine, Rev. B DV), so I can only imagine how many times this rubber seal has been stretched. Here's a pic, 8 tears in total... Yikes!  :scared: I'm surprised that VW aren't recommending that these are checked at some point.  :sad1:
I replaced it with a Rev D. (part number 06H 145 710 D)  <-- 31/03/13: I've now changed it again to a Rev G. (part number 06F 145 710 G) which is even better.  :happy2:
PS. I know there's a lot of DV stuff on the forum already, but for any other novices like me, you can never have enough info/tips.
Rich.
« Last Edit: March 31, 2013, 03:08:31 pm by Richie_101 »
Offline ripmateyy
Re: Another vote for checking your DV!
« Reply #1 on: February 24, 2013, 11:56:13 am »
I know that a fault with this can show up through a scan BUT could it be at fault and NOT show up on a scan?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: February 24, 2013, 12:09:23 pm »
^^^Absolutely.
'07 Red manual
Offline ripmateyy
« Reply #3 on: February 24, 2013, 12:16:15 pm »
^^^Absolutely.
Best get out and have a look then  :scared:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #4 on: February 24, 2013, 12:19:09 pm »
Bit cold for that...hypothermia and frostbite await :laugh:
'07 Red manual
Offline craig_GTI
  • -Given: 18
« Reply #5 on: February 24, 2013, 03:34:12 pm »
I was suppose to do this today as well, can't wait to see if mines gone.. I'm replacing mine with a rev G, this is right isn't it? Why did you use a rev D
Tornado red mk5 Golf GTI 5 door.
Offline ashw831
« Reply #6 on: February 24, 2013, 03:51:52 pm »
Swapped mine yesterday for a rev G.. What a difference it makes! I do miss my turbo whistle a bit, but as soon as it starts boosting, puts a small on my face instantly!! It is a totally different car now.  :driver:
Offline craig_GTI
  • -Given: 18
« Reply #7 on: February 24, 2013, 03:54:53 pm »
Great stuff, itchin to do this now! Iv got the part just need to find the time..
Offline alexmccabe
    • Alex McCabe
« Reply #8 on: February 24, 2013, 03:55:45 pm »
Mine whistles under acceleration. I just thought it sounded cool, I didn't realise it wasn't supposed to. Haha. I'll get one changed ASAP.
MK5 Golf GTi 197BHP Tornado Red
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #9 on: February 24, 2013, 04:03:03 pm »
I'd use G too mate, I've had D in for a few months and I think it's leaking... Boost requested isn't matching boost actual....one more job in the pipe line to swap out.
Offline alexmccabe
    • Alex McCabe
« Reply #10 on: February 25, 2013, 02:13:39 pm »
I went to the stealers and asked them about my DV. I read that the car shouldn't whistle under acceleration and I asked them about this. They said that the 2005 MK5 is pretty noisy anyway and that they don't really know if it would be the DV.
Now, should my car make a really cool whistle under acceleration or not? I like the sound but if it is destroying power and fuel consumption, I will replace it with a rev G valve.
  • -Receive: 427
« Reply #11 on: February 25, 2013, 03:04:00 pm »
^^^^ replace it with a Revision G as a matter of course. Only £40 and worth every penny.  :happy2:
Offline alexmccabe
    • Alex McCabe
« Reply #12 on: February 25, 2013, 03:10:21 pm »
Actually dealer says £28 inc. VAT, so even better. Thanks
Offline Kalpsn2000
  • -Receive: 56
« Reply #13 on: February 25, 2013, 03:12:27 pm »
Your dealer isn't the stealer I usually visit then :laugh:
Offline Richie_101
« Reply #14 on: February 25, 2013, 04:05:35 pm »
If it sounds like this, then I'd say it's definitely busted. (The alarm bells would already be ringing though as there's no acceleration at all here!)
http://www.youtube.com/watch?v=Q1GCci5l9JM&feature=player_detailpage
Mine didn't sound that bad, more like this...
http://www.youtube.com/watch?v=iU2m_O38wwg&feature=player_detailpage
I went with the Rev. D, because I read that it's more solid with the piston and not the diaphragm design, but everyone on this thread is recommending the G. Hmmmm.... what to do?... :sad1: <-- 31/03/13: I've now changed it again to a Rev G. (part number 06F 145 710 G) which is even better, so go with the G. :happy2:
Rich.
« Last Edit: March 31, 2013, 09:33:58 pm by Richie_101 »
