Author Topic: Problem: Engine dies a couple of seconds after ignition  (Read 1935 times)
Offline jsklair
« on: February 23, 2013, 07:53:45 pm »
I turned my car on this afternoon, and after a few seconds the revs died to nothing.
I tried again a few times, with the same result.
I thin tried with my right foot planted on the accelerator, this made it rev louder at the start; but it still died a second or two later.
One thing to note, the rev meter did not move once, it was planted on zero.
The guy driving the recovery truck had a look, and said it was most likely a dead fuel pump.
Does anyone else have a better idea?
Saintsteve
Re: Problem: Engine dies a couple of seconds after ignition
« Reply #1 on: February 23, 2013, 08:03:53 pm »
A fuse blown on said fuel pump ?
« Reply #2 on: February 23, 2013, 08:09:39 pm »
Sounds like an immobiliser related issue to me.
Offline jsklair
« Reply #3 on: February 23, 2013, 08:15:57 pm »
Now that you mention it, I remember the hazard lights going off when I last turned the car off (the alarm horn has not worked for a few months, so no noise).
If it is the immobiliser,  how do I remobilise it?
Offline james
« Reply #4 on: February 23, 2013, 08:36:49 pm »
put the key in and turn,  does the immo light go out or flash?
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #5 on: February 23, 2013, 08:44:21 pm »
My car does this now and again then starts up on the second try,  i just put it down to a cold start?
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline jsklair
« Reply #6 on: February 23, 2013, 08:58:14 pm »
The immobiliser light goes out after a second.
Does this mean the immobiliser is not the issue?
Offline jsklair
« Reply #7 on: February 23, 2013, 09:26:20 pm »
I replaced the fuel pump fuse (fuse 27 (15 amp) as per the manual), and still no joy.
Offline james
« Reply #8 on: February 24, 2013, 04:27:45 am »
it is not an immo issue then,  you need your car to be scanned.
Offline jsklair
« Reply #9 on: February 24, 2013, 09:37:36 am »
Do I have to go to a dealer, out well most specialists have the required scanning equipment?
Saintsteve
« Reply #10 on: February 24, 2013, 09:43:11 am »
Look on this website. Look at the VCDS register and see if a forum user can scan it for you that's local to you perhaps  :happy2:
Offline jsklair
« Reply #11 on: February 24, 2013, 04:03:23 pm »
Thanks for that.   I've checked there's no one in the Slough area.  :sad1:
I'll probably have to for it to the specialist in it's state.
Is there anything else obvious that it could be?
Would a fuel pump problem stop the rev meter from working?
Offline PDT
  • -Receive: 142
« Reply #12 on: February 25, 2013, 03:48:40 pm »
A friend of mine is in your area: http://www.tuningfactory.co.uk/
Name is Tim  :happy2:
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #13 on: February 26, 2013, 06:56:24 pm »
happened to my brother when he took out the ESP button when wrapping the console. car wouldnt start without the button plugged in? weird.
