Author Topic: Headlight washer system - not working!  (Read 7650 times)
Offline chungster
« on: July 18, 2009, 10:11:43 am »
bit annoyed with this, as its just out of warranty!!
have had an inde look at it...no blown fuse, no errors in ECU....
system works via water pressure from a pump which is on the washer reservoir i believe.
so is it likely that the pump has failed and just needs replacing? anyone else had this problem?
Replacement pump is only £50 all in (needs another part) so i could in theory take the front bumper off myself and replace it.
Parts guy did say it could be leak in the system so not enough pressure is getting to the jets to force them out and spray.
But rather than wasting more dosh on diagnosing actual prob and then being told it is the pump (thus extra charge for fitting it) i'm thinking i might just buy the part and replace it myself.
Any words of advice before I go down this road?
Re: Headlight washer system - not working!
« Reply #1 on: July 18, 2009, 03:25:14 pm »
so what exactly is the problem fella?
you have no water pressure at the jet? or the actual pump isn't working?
Offline chungster
« Reply #2 on: July 18, 2009, 03:55:57 pm »
the one for front windscreen/rear screen works fine.
the headlight ones (both side) don't fire anymore....like it used to like after every 5 blasts on the windscreen.
can't find many references on the web to people seeing the pump fail. wierd.
the inde garage didn't go any further to checking if it is the pump....as it would have meant more labour hours and front bumper off (i needed to go to airport) so left it.
« Reply #3 on: July 18, 2009, 04:54:22 pm »
the the units come out but dont squirt?
its worth checking all of the little couplings that lead to the jet as they can clog up depending on the type of screenwash you use
has your fluid got really low or run out completely recently?
Offline chungster
« Reply #4 on: July 18, 2009, 05:34:23 pm »
nope they don't pop out at all, as they r forced out by water pressure from the pump. so thats why i think the pump needs replacing.
it did run low...but i topped it up straight away. it stopped working before the warning came up anyway...just not bothered to get it looked out till my oil service!
Offline billyboy
  • Billy lar
« Reply #5 on: July 18, 2009, 07:32:34 pm »
daft one, but your light switch is set at auto yes.....
bill
Offline chungster
« Reply #6 on: July 18, 2009, 08:46:02 pm »
bill
yup. always. but the headlight washers work every after 5 blasts to windscreen don't it, regardless of where switch is positioned?? that's how its always been anyway (so i knew it was working)
Offline bigbo
« Reply #7 on: November 15, 2009, 03:59:56 pm »
mine seems to have packed up to, ive cleaned the jets out but i cant hear my pump working so im guessing thats failed. is this easy to replace myself?
Offline clive_gti
« Reply #8 on: November 16, 2009, 12:02:42 pm »
Mine stopped working but it was a blown fuse.. apparently its not uncommon for that one to go.  Double check that's not the issue, i'll try to dig up the thread which shows which fuse to check.
edit: here it is: http://www.golfgtiforum.co.uk/index.php?topic=101847.20
see last few posts
« Last Edit: November 16, 2009, 12:04:14 pm by clive_gti »
Offline clive_gti
« Reply #9 on: November 16, 2009, 12:05:49 pm »
bill
Only if the headlights are ON (i think)
