Author Topic: Low oil pressure warnings  (Read 1352 times)
Offline Lukesgti
« on: February 23, 2013, 10:20:26 pm »
Last night on my way home from Manchester my dash board lit up with low oil pressure warning light the car has been back in about two month ago for this problem an was all fine till now  :jumping:, managed to get it to a garage this morning and I started work on it I took the sump off an the pick up filter in the sump was blocked to the stage where only drops were coming through after cleaning it and putting back together and erasing errors all seems good drove it for about two hours tonight on a spirited run one would say and no more errors thought I'd share in case anyone else was having the same problem.
Offline Scrubadub
  • Soon to be "bagged"
Re: Low oil pressure warnings
« Reply #1 on: February 23, 2013, 10:44:30 pm »
What sort of milage has your engine done and is it regularly serviced?
Fun bags
Offline Lukesgti
« Reply #2 on: February 23, 2013, 10:47:50 pm »
It's done 120,000 on a 06 according to the service book it has missed one at 90
« Reply #3 on: February 23, 2013, 11:13:56 pm »
Do you know if long life oil has been used at service time?
Offline Lukesgti
« Reply #4 on: February 24, 2013, 10:15:01 pm »
No due to only having the car for the past 3 mouth
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: February 27, 2013, 12:44:20 pm »
It should say in the service book what oil was used at the last service if it doesn't give the garage a call.
