Author Topic: Springs..and Shocks Again !  (Read 1307 times)
Offline Ranbeer Singh
« on: February 24, 2013, 04:28:18 pm »
Hi All!
Advice / Experience needed..
I have one of the following options available to me.. I am after a lowered look with the most comfortable ride. Cheapest to most Expensive..
Eibach PRO - told I can use OEM shocks on these.. True??
Eibach SPORTLINE - told shocks would need to change. Prefer the drop on these but will the ride be similar to OEM? i have been told I would need to change the shocks unlike the above?
H&R CUP KIT - from what I have read the springs are a stiffer ride than the Eibachs. Need to know if the kits shocks would compensate and be just as good as the other options listed?
Bilstein B12 KIT - as the above kit but with Eibachs and Bilstein shocks.. Only heard good things about these but it doesn't come cheap!  Is the ride better than the H&R Kit?
Sorry for the number of questions but need the GTI to be just right  :happy2:
Thanking you in advance.
Rick
GTI-DSG-2007
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Springs..and Shocks Again !
« Reply #1 on: February 24, 2013, 04:34:02 pm »
Dont see why you would need to change your shocks straight away with just some sportline springs. I have H&R springs on standard shocks with no problems
Offline Raffe
« Reply #2 on: February 24, 2013, 05:06:08 pm »
Running Sportlines on standard shocks and IMO the ride as been compromised as it is choppy at times, will be adding some Bilstein B8's ASAP to rectify.
« Reply #3 on: February 24, 2013, 08:00:13 pm »
So you think just go for the b12 kit?
Rick
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #4 on: February 24, 2013, 08:49:49 pm »
Don't mean to hijack, but with harders stiffer shocks and springs would they/or could they cause more wheel hop???
Silver is the way !
Offline tonto83
« Reply #5 on: February 24, 2013, 09:19:37 pm »
If there's high mileage on your current shocks then fitting lowering springs will accurate their wear.  I have the H&R cup kit fitted.  Ride is stiffer but the handling is a huge improvement.  On decent roads ride comfort isnt any different to stock.
Offline GNJ_Motorsport
  • -Receive: 20
    • GNJ Motorsport
« Reply #6 on: February 24, 2013, 10:24:49 pm »
There is absolutely no doubt that fitting a full kit is the better option but it all comes down to budget.
Fitting just springs, most notably the H&R or Sportlines gives a nice stance and improved handling with standard dampers but if you are willing to spend the money for a full kit then I'd do so definitely.
My GTI is still on the Sportlines it came with and is on 78k miles and it handles and rides quite well for a car on just uprated springs I think. That said a full kit is going on soon and I expect a big improvement.
0% Interest Free Finance Available On All Parts NOW
www.gnjmotorsport.com
info@gnjmotorsport.com  -  01254 883345
Facebook  -  Instagram
« Reply #7 on: February 25, 2013, 11:58:25 am »
Thanks for the help so far.
Now its either H&R Cup Kit or the B12!
Its very hard to choose bewteen the two -- anyone have any experiences/knowledge they wish to share?
RICK
Offline flashp
  • -Receive: 65
« Reply #8 on: February 25, 2013, 10:29:01 pm »
I can recommend a B12 kit. I have done other bits at the same time, but that element of the work I had done is perfect.
Gone but not forgotten :-)
