I took two apart yesterday to make one good one.
It's in four parts. You have the upper FSI Turbo piece that doesn't need removed, there is the intake scoop with the springy clip that needs removed to split the cover.
Then if you flip it over the cover splits into two when you slacken all the torx screws. At this point you can swap out your damaged bottom section.
I'm sure these are one piece though when it comes to buying another one.
