Author Topic: Pcv valve  (Read 872 times)
northyracing
Pcv valve
« on: February 26, 2013, 05:32:07 pm »
Been havin idle problems and juddery feeling so checked my pcv today I done the blow down the pipe test. I took it off inlet manifold side and blew down the pipe and took oil cap off and you could hear that I was blowing straight through the pcv into the engine also noticed the pipe had quite abit of engine oil in it would this suggest the pcv is naffed
« Last Edit: February 26, 2013, 06:01:18 pm by northyracing »
Re: Pcv valve
« Reply #1 on: February 26, 2013, 05:36:49 pm »
With the engine on, pull the Dipstick out, if the engine starts to run rough then all is well but if it continues to run smoothly then it needs replacing.
northyracing
Re: Pcv valve
« Reply #2 on: February 26, 2013, 05:57:31 pm »
It runs rough wen dip stick is out but can blow straight through pcv
