Author Topic: Clutch slip on stage 1 map  (Read 3387 times)
Offline matty_jetta
« on: July 19, 2009, 06:52:55 pm »
Well i was on the rollers yesterday at awsome gti.
I have a revo stage 1 map and the map shows i get a small amount of clutch slip at max boost, 4k ish.
Anyone else had any clutch problems?
Currently i have switched the map off and am going to get my revo settings turned down. Boost is at 8 at the minute.
Last thing i need is to pay for a new clutch, will i have done much damage to mine?
On the other hand i ran 259.9 bhp and over 300ft/lb torque.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Clutch slip on stage 1 map
« Reply #1 on: July 19, 2009, 07:19:22 pm »
It seams to be more heard of on the remapped ED30 than the GTI but with 300ft/lb of torque it's not suprising.
Turning down the Revo settings will help for now but an uprated clutch is something you should really start to consider as it will get worse over time.
Offline matty_jetta
« Reply #2 on: July 19, 2009, 07:28:54 pm »
yer i am getting the boost turned down this week hopefully, will this involve sending my switch box away do you know?
will i have done much damage to my clutch then?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: July 19, 2009, 07:30:42 pm »
If you have the Select Plus switch you can do this yourself, just plug it into your PC and you can adjust the presets sorted under A,B & C  :happy2:
Offline chungster
« Reply #4 on: July 19, 2009, 07:32:35 pm »
mine started to slip just after REVO was added. And I was only running Boost 6.
I would get a uprated Sachs clutch fitted and enjoy the Revo map properly.
Offline matty_jetta
« Reply #5 on: July 19, 2009, 07:53:50 pm »
How much approx would a sachs clutch be fitted?
Theres no way i will be able to go stage 2 with mine without
Offline chungster
« Reply #6 on: July 19, 2009, 09:15:55 pm »
about £700 all in??
Depends if your flywheel needs replacing. I didn't on mine tho.
Offline matty_jetta
« Reply #7 on: July 19, 2009, 09:25:25 pm »
oh heck, thats £700 i dont have.
Is it much more for a fly wheel if needed?
Wonder why mine is doing this when other people are running much more on standard clutches?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #8 on: July 19, 2009, 09:36:02 pm »
I,ve recently had REVO ST2+ fitted to ED30 DSG.
My clutch slips when nailing it  on aggressive map setting. :sick:
Anyone know howmuch a DSG clutch is?
I don't think there are many options on the DSG clutch packs as yet in the UK.
When Hurdy had this on his a DSG service sorted it out.
Touch wood mine had been OK on Stage 2+ but I have just had my DSG box serviced.
Offline chungster
« Reply #9 on: July 19, 2009, 09:41:56 pm »
flywheel is another £400 odd!!!
the clutch in the std GTI is not the same as the one in the ED30. You could go for one of those instead i suppose.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #10 on: July 19, 2009, 09:42:48 pm »
Little bit puzzled here steve..
Why would an oil service help with clutch slip?I assume this is all that,s done on DSG service?
Not sure of the reason why but it certainly help Hurdy  :confused:
What mileage is yours at??
Also is there any difference with the DSG box from the GTI and the ED30??
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: July 19, 2009, 09:55:06 pm »
^^^ Well I hope it's not the friction plates as I can't see that being a cheap job  :scared: :scared:
Offline WhiteGTI
  • F-A-S-T
« Reply #12 on: July 19, 2009, 10:06:00 pm »
Oh really?? My clutch has never slipped..........touch wood!
2006 E46 BMW M3 - 343hp
« Reply #13 on: July 19, 2009, 10:45:00 pm »
The gearbox will be touching 60K.(so i imagine the friction plates will be worn).
As far as I know ED30 and stock GTI dsg boxes are the same.
I don't know why it cleared the slip up, but it did. I think VW also rest the DSG settings on the service too. :happy2:
I did ge ta little bit of slip when abusing it at the Pod, but I then had the GIAC remap done, which increases the oil pressure in the 'box and this has made it a whole different gearbox :drool: GIAC claim that their map uprates the handling capacity of the box to 500nm and I can believe it as it is simply spot on now :notworthy:
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #14 on: July 20, 2009, 09:29:22 am »
Out of interest is that 260bhp achieved with only a Stage 1 Revo remap, or does your car have other modifications?
