Author Topic: Interior light failure  (Read 2073 times)
Offline mance23
« on: February 28, 2013, 06:15:36 pm »
I have just been replacing my interior bulbs to LED ones , I just about finished and removed the boot one and it seemed to work once and now it seemed to have tripped the circuit ?
I scanned it with my VCDS and it now reads to faults which are listed below, any idea ? :confused:
2 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01111001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 101805 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.25 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00111100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 101805 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
Audi A4 Avant - Teesside VCDS available
Offline skard
  • -Receive: 245
Re: Interior light failure
« Reply #1 on: February 28, 2013, 06:47:32 pm »
You've probably blown the fuse - it is the only 7.5A one in the fusebox (behind headlight switch)
Offline andybon
« Reply #2 on: February 28, 2013, 08:01:22 pm »
Deffo a blown fuse. I did the same, replace with a 7.5a fuse and it will work again!
How hard can it be?
Offline mance23
« Reply #3 on: February 28, 2013, 08:09:18 pm »
Will have a look tomorrow guys and see what it is.
