the only thing i arent sure about is the connection onto the CECM, i dont suppose you have more detail/pictures about how and where it is fitted
OK...
The wiring diagrams above show three wires running to the CECM:
L2 - connector L, pin2
I2 - connector I, pin 2
C1 - connector C, pin1
The CECM is located underneath the dash just above the bonnet release lever, behind the fuse box.
This picture shows the CECM when totally removed from the car, note each connector is labelled:
![](https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg78.imageshack.us%2Fimg78%2F1663%2Fcecm2te4.jpg&hash=e9f0d25fdc98bb636da30b440e3e00c6f1981f96)
Two red levers need to be pulled towards the bonnet release lever to unlock the wiring harnesses for removal.
You can then pull the relevant connector out from the CECM, so you can insert the relevant wire into the correct location on the harness plug.
Once the wires are in place, refit the connector into the CECM and push the red levers back into position to lock in the wiring harnesses.
Hopefully, that should clear things up for you
![happy2 :happy2:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/happy2.gif)
Jas
