Which loom did you buy? If you bought the 2007+ loom then it could be its for a lhd and you will have to swap the looms that are under the seats to convert them back to rhd.
Sounds like the loom you got might also be for the memory seats.
Sent from my SM-G955F using Tapatalk
Got hold of the instructions from kufatec ......
I've ordered the 'until 2006' as the seats were from a golf from this era...
Pic....
![](http://)
FFS!!!!! Why is everything so hard... Copy and paste from a pdf has screwed up the text... Can't seem to upload the image either....arrrrrgggggghhhhh
Manual wiring heated seats Golf V until October 2006
Wire configuration with gray wirings: 2x Permanent positive (Imprint Dauerplus Kl.30)
2x Permanent positive (Imprint Sitzverstell. Kl.30)
3x Ignition positive (Imprint Zündung Kl.15) 1x Double crimp (Imprint C – PIN 1)
Connection Climate control unit 20-pole connector: 1x Grey wire (0.352) (Imprint Blau/Gelb)
1x Grey wire (0.352) (Imprint Blau/Rot)
1x Grey wire (0.352) (Imprint ZP Klima) -
2x Cable lug (Imprint Masse)
Connection with free fuse at the fuse box (20 ampere each)
Connection with free fuse at the fuse box (30 ampere each)
Only at item 34048-2 & 34048-4
Connection with free fuse at the fuse box (15 ampere each)
Control unit central electric Connector C – PIN 1
PIN 10 (Climatronic) – PIN 13 for Climatic PIN 11 (Climatronic) – PIN 12 for Climatic PIN 12 (Climatronic) – PIN 15 for Climatic
Ground A-Column, driver site
