Author Topic: gearbox oil filler hole  (Read 2454 times)
Offline andygo
« on: March 01, 2013, 11:01:58 am »
Where is it on a 07 manual box?
Offline danfalcon
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92069.0.html
Re: gearbox oil filler hole
« Reply #1 on: March 01, 2013, 11:00:39 pm »
i dont know if it differs to which gearbox you have (most likely will) but i have a 5 speed manual on a 1.9TDi and it is about 5 inches above the drain plug and has the same style, easiest way to describe it, is that it looks like the head of a bolt will fit in there
hope this helps
« Last Edit: March 02, 2013, 09:24:17 am by danfalcon »
Offline apples12
« Reply #2 on: March 02, 2013, 01:07:32 am »
again, i think it differs on each box...buuuut when i had it done on my 6 speed, the VW manual stated it had to be refilled via the reverse sensor hole (So had to remove the reverse sensor and refill via a hose and funnel)
reason for that was that the fill level is halfway up the inspection hole
http://www.golfmkv.com/forums/showthread.php?t=173428
MK6 GT TDI  - CW - LUX pack
GONE
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #3 on: March 02, 2013, 09:59:38 am »
I thought the gearbox oil was a 'lifetime' item and never needs to be changed.
Why did/are you guys changing it?
'07 Red manual
Offline apples12
« Reply #4 on: March 02, 2013, 10:17:24 am »
vw say 'lifetime' which in actual fact means about 150,000 miles or thereabouts... if you think the gearbox's gears go up and down in temperature, the oil in there takes quite a bashing, for the cost of the oil and the time it takes its just a bit of preventative maintenance to swap out the old oil for nice new vw oem oil. plus it can make the gear changes a bit smoother
GONE
