Author Topic: Polar fis  (Read 2169 times)
Offline Gtiain
Polar fis
« on: March 01, 2013, 02:42:11 pm »
Can someone please explain to me what this is?  :popcornsoda:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Polar fis
« Reply #1 on: March 01, 2013, 02:47:23 pm »
It's an add on box you plug into the car's canbus system and it enables you to see most of the parameters in the highline display that you normally would need VCDS for.
As extra it can be used to several comfort adjustments, such as comfort turn signal number oftimes indicating, dip mirror when parallel parking and others.
I hope this helps??  :smiley:
Over the top mod list ;o)
Offline Gtiain
Re: Polar fis
« Reply #2 on: March 01, 2013, 02:51:17 pm »
Perfect thanks  :happy2:
So are these hard to install?
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Polar fis
« Reply #3 on: March 01, 2013, 03:33:00 pm »
not as hard as through twas going to be, depending on what age your car is depends on wher eit is located though. to be honse i found trying to get the canbus back in its cradle was harder than getting to it and plugging the polar in  :wink:
Offline Gtiain
Re: Polar fis
« Reply #4 on: March 01, 2013, 03:35:51 pm »
I have a 60 plate mk6 gti now, depending on how hard it is I may get one. Does it need coding via vcds?
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Polar fis
« Reply #5 on: March 01, 2013, 03:38:44 pm »
no, you can upload latest firmware off polar site onto box, fit it, cycle the ignition it should then come up on highline but then it goes and you have to disconnect battery for 10 min fot it to return. Bacillus is the man to ask re any polar queries  :happy2:
Re: Polar fis
« Reply #6 on: March 01, 2013, 03:41:11 pm »
Did I hear my name being called?  :evilgrin:
And no, you don't need vcds for any coding with the polar.
Offline Gtiain
Re: Polar fis
« Reply #7 on: March 01, 2013, 03:45:24 pm »
I'm guessing that you being the polar fis man, you would highly recommend it???
Re: Polar fis
« Reply #8 on: March 01, 2013, 03:50:15 pm »
Personally I now find it invaluable but then I like to see everything is running in spec.   :smiley:
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Polar fis
« Reply #9 on: March 01, 2013, 03:57:00 pm »
I think if you have Highline it is a must as you are not utilising your Highline fully without it
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Polar fis
« Reply #10 on: March 01, 2013, 04:10:41 pm »
Mk6 fitment to the canbus is far easier IIRC
Join the auto polar forum there's a how to guide for fitting to the mk6  :happy2:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Polar fis
« Reply #11 on: March 01, 2013, 06:00:55 pm »
Here's a pic of one of the parameters screens in my mk5.
Theyre customisable to show whst you want, from a fixed list of parameters.
Jas
VCDS (Preston, Lancashire)
Offline McKeann
Re: Polar fis
« Reply #12 on: March 01, 2013, 06:37:31 pm »
How much is it to add this to an 06 mk5 with highline dash????
