Author Topic: Snow foam lance set up  (Read 1060 times)
Offline mad_pete
« on: March 04, 2013, 02:01:01 pm »
Stupid question but how do people set their lance up ? I have the nozzle that controls the 2 small plates at the front and the valve with plus and minus on the top. I was getting some nice foam but I played with the settings today and can't get the foam back.
  • -Receive: 291
Re: Snow foam lance set up
« Reply #1 on: March 04, 2013, 02:35:44 pm »
The nozzle controls the width of the spray.
The dial on top controls the air mixture - adjust it fully one way and then the other to see which setting suits you.
If it still doesn't work, there might be a problem with the lance itself. May require servicing depending on how old it is.
Offline mad_pete
« Reply #2 on: March 04, 2013, 06:07:35 pm »
Thanks it's new. Maybe I need to get the air mixture right before I change the spray width.
Offline mad_pete
« Reply #3 on: March 28, 2013, 08:03:23 am »
Yes mines defiantly not picking up from the bottle. I found a service guide I may try that.
Offline mad_pete
« Reply #4 on: March 31, 2013, 07:45:25 pm »
Left it in hot water for 10 minutes and if
it was much better.
