Author Topic: Mk5 golf tdi cluster swap HELP!!!  (Read 9557 times)
Offline Redgtr
« on: March 04, 2013, 10:22:01 pm »
Right I need help please
My 2005 golf tdi the fuel gauge ain't working
Me and my friend (skoda tech) traced it to be the dash,so rang vw and they say its new dash only as a second hand unit can't be recoded ? Is this true?
Plus I would like to fit high line clocks to have the average mpg, miles left on whatEva fuel is this possible ?
Somebody please shed some light on this for me
I live in Chepstow South Wales also if anyone is local that can help :)
Cheers jason
Offline chrisr763
  • -Receive: 62
Re: Mk5 golf tdi cluster swap HELP!!!
« Reply #1 on: March 04, 2013, 10:51:10 pm »
Cheers jason
I presume you have the lowline cluster then? Do you know what the last 4 digits of your clocks are... Should be like 961 B
Offline Redgtr
« Reply #2 on: March 04, 2013, 10:56:10 pm »
They are 951 g I believe?
Offline chrisr763
  • -Receive: 62
« Reply #3 on: March 04, 2013, 11:01:47 pm »
At least you have some idea of your unit. Your best bet is to talk to someone in the 'know' I would advise giving Eddie-NL a PM, with your current information. He should be able to guide you in the right direction!  :happy2:
Offline skard
  • -Receive: 245
« Reply #4 on: March 04, 2013, 11:11:02 pm »
You have lowline, even midline is an upgrade, so 96x clocks.
I'd get highline ones since you're going through the effort. You'll need a new steering control module to get trip functions, from memory and an MFA+ stalk (wiper stalk with rocker button) or multifunction wheel to flick through menu's.
The plus side is you can DIY this very cheaply.
Offline Redgtr
« Reply #5 on: March 05, 2013, 06:49:14 am »
But can you recode a second hand dash cluster?
Offline Redgtr
« Reply #6 on: March 05, 2013, 07:06:07 am »
I already have cruise control so will I already have the correct steering control module?
Even if I source all these parts I still have nobody to code it all :(
Offline skard
  • -Receive: 245
« Reply #7 on: March 05, 2013, 08:47:15 am »
If you have cruise your module will be ok, ideally you want 971 or 972 clocks (970 if that's all you find) and diesel versions, and the wiper stalk I mentioned.
973/974 clocks can be used but you can't recode these in the same way, only a few people have the ability to do them.
You can cheaply DIY using this guide http://furmanka.blogspot.co.uk/2008/02/mk5-mfd-plus-hi-line-cluster.html
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: March 05, 2013, 09:03:47 am »
yes 2nd hand modules can be coded as long as you can extract the SKC from it.
Earlier models can easily done if you have the correct tools, or if its a 973/974 clocks as mentioned earlier, then Eddie_NL or Kalu can do them for you.
Offline Redgtr
« Reply #9 on: March 05, 2013, 06:22:15 pm »
Ok great so could Eddie or Kalu please get in touch with me I need this sorted cheers for your help guys
Offline Redgtr
« Reply #10 on: March 07, 2013, 12:14:27 pm »
Could someone please get me in touch with Eddie or kalu as I need to get this sorted cheers jason
Plus I'm going to ultimate dubs Sunday if anyone can meet up n give me there number that would be great cheers
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: March 07, 2013, 12:16:36 pm »
your only a couple of posts away from being able to PM
you can email me, I don't think it is hidden in my profile
Cluster and Key coding
Location Great Yarmouth
Offline chrisr763
  • -Receive: 62
« Reply #12 on: March 07, 2013, 12:16:57 pm »
It is Edd  :wink:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: March 07, 2013, 12:30:51 pm »
Offline Redgtr
« Reply #14 on: March 07, 2013, 04:01:11 pm »
Great I have emailed you on eBay ed could you txt me on 07872474279 cheers
