Author Topic: mk5 gt tgi 140 New turbo  (Read 573 times)
Offline Murraymint
« on: March 05, 2013, 07:32:05 am »
I'm going to be getting a mk5 gt tdi 140 soon, but I've read a lot that the turbos are kack. If I find ome that's still got its original turbo, would be worth buying a new turbo and fitting it? Also hoe hard is it to fit a new turbo?
Re: mk5 gt tgi 140 New turbo
« Reply #1 on: March 05, 2013, 07:46:47 am »
All depends what the turbo is doing  and peforming on the and also it was early ones that were the problem
Offline Polo6n1600i
« Reply #2 on: March 05, 2013, 04:22:38 pm »
Just bought a Pd140 in october - ok its a Jetta, but same engine!
Its all about each individual car and how its been looked after - the oil feed pipe has loads of nasty 90 degree corners and it the oil hasnt been changed enough then they can get clogged and end up starving the turbo of oil = bearing failure normally.
There is no way to tell if a turbo is on its last legs unless there are signs of wear already. Check the service history, make sure there are plenty of oil changes - every 10K with longlife oil I was told was recommended (the longlife you normally get the oil change done every 20K, but this is way too long a service interval if you want your car at peak running.
If you want to keep the car running well a set of the darkside oil feed and returns would remove the worry of the clogged oil feeds (as theirs is a flexi hose) and good oil and filter every 10K. if it lets go in the future then you can always upgrade...........
