Author Topic: Maf sensor problems  (Read 849 times)
northyracing
Maf sensor problems
« on: March 05, 2013, 09:10:25 am »
Any shed any light on how I can tell if my MAF sensor is naffed I ain't got vagcom or anything like that so just need advice on any little tricks I could try also what symptoms would I get if it is naffed any help would be wicked
Re: Maf sensor problems
« Reply #1 on: March 05, 2013, 02:38:21 pm »
If your MAF is fooked, disconnect it and go for a drive. You will get a warning light but the car should drive fine.
« Reply #2 on: March 05, 2013, 02:45:43 pm »
northyracing
« Reply #3 on: March 05, 2013, 03:55:39 pm »
I unplugged the maf and it runs just the same as when it's plugged in which is a Little hesitant on low speed and a juddery feel when at a stand still at idle
« Reply #4 on: March 05, 2013, 04:44:22 pm »
Oh well it's not your not your MAF, assuming you took it for a drive.
northyracing
« Reply #5 on: March 05, 2013, 05:03:40 pm »
Just can't work out what it is as I have replace the dv, the pcv coils and plugs so was just assuming it wa the maf
