Author Topic: How to remove oil filler neck?  (Read 2925 times)
Offline craig_t
  • Craig
« on: March 09, 2013, 12:09:06 pm »
As in title, can anyone tell me how to remove this.
Admin notice, sig pic removed for being to big.
  • -Receive: 427
Re: How to remove oil filler neck?
« Reply #1 on: March 09, 2013, 12:18:58 pm »
Here you go.  :happy2:
~~ Clicky here ~~
EDIT: do it when the engine is warm, will help.
Offline craig_t
  • Craig
« Reply #2 on: March 09, 2013, 12:20:19 pm »
~~ Clicky here ~~
Have you done this urself?
  • -Receive: 427
« Reply #3 on: March 09, 2013, 12:27:42 pm »
^^^^ no matey i haven't as I always use an engine cover, whether with or without a CAI i place and with the engine cover on it would be a pain to get at. A fair few peeps have though.
  • -Receive: 291
« Reply #4 on: March 09, 2013, 03:11:00 pm »
Be aware that once you take it off, you can't put it back on again. You have to buy and fit the whole assembly.
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #5 on: March 09, 2013, 03:12:39 pm »
I know it's a bit nasty... but couldn't you stick it back on with some high temp adhesive?
Offline craig_t
  • Craig
« Reply #6 on: March 09, 2013, 03:36:15 pm »
I'm pretty sure you could stick it back on as its only stuck on from the factory.
Offline chudds
« Reply #7 on: March 17, 2013, 04:01:42 pm »
so after removing the filler neck it just has the standard bayonet fitting so you can still use the same cap? if i were to make a liner with a threaded cap id just need to use high temp adhesive to make sure it says in place?
