Author Topic: Sudden slump in power????  (Read 2860 times)
Offline Beattie
« on: March 09, 2013, 07:19:30 pm »
Hi all,
I was driving up quite a steep road and whilst doing so i was going about 40mph. When I got to the top it basically slumped and i lost all power, there wasnt much pulling or torque whatever you call it. It seems my revs are going higher than usual and my speedo and car isnt gaining the usual pulling power it does. Im remapped from 140 to 190 and it doesnt even seem like 100.. really not sure whats wrong but theres no smoke, noises or anything unusual. Just doesnt drive normally..
It seems 1st and 2nd gear isnt great but once in 3rd its not right either but will pull ever so slightly better.. I can hear my turbo noise as usual and doesnt sound any different. So cant say it was the turbo.
wont get it into a garage until monday so anyone got any idea of what it may be??
Its a 2007 2.0 TDI 4motion.
Cheers, Craig.
« Last Edit: March 09, 2013, 07:21:42 pm by CDB »
MK6 2.0 GT Tornado Red.
Offline skard
  • -Receive: 245
Re: Sudden slump in power????
« Reply #1 on: March 09, 2013, 07:23:19 pm »
Look for a hose that's come off, or if one has split.
In particular, check your intercooler piping as they have crappy joints (might have to remove engine tray).
Offline Beattie
« Reply #2 on: March 09, 2013, 07:24:38 pm »
I wouldnt know where to start looking for all that to be honest. Im guessing if it were a hose it may of split with the pressure of me booting it up the hill?
« Reply #3 on: March 09, 2013, 07:29:05 pm »
Clutch slipping??
Offline Beattie
« Reply #4 on: March 09, 2013, 07:30:24 pm »
Not sure what it is hence why im asking for info here. It changes gears fine mate its just the lack of power....
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #5 on: March 09, 2013, 07:35:25 pm »
Does sound like clutch slip; revs rising, lack of go...  esp. because your mapped.  How many miles?
Offline Beattie
« Reply #6 on: March 09, 2013, 07:46:49 pm »
86k odd.. Well if its my clutch then thats only been about 6 months ive had it remapped. How much does this repair usually cost about? Im up in Orkney working at the moment so not got a great selection of garages here and the only VW "specialist" aparently wants £80 per hour...
Offline Beattie
« Reply #7 on: March 09, 2013, 07:47:42 pm »
My revs go higher than usual like when im accelerating my speed rises but my revs are way above normal..
Offline gazbutS3
« Reply #8 on: March 09, 2013, 07:51:40 pm »
Sounds like a slipping clutch
Offline sanj
  • -Given: 17
« Reply #9 on: March 09, 2013, 07:52:59 pm »
Defo clutch mate,I had this on my Edition30,A NEW sach's clutch sorted that out! :smiley:
Offline Beattie
« Reply #10 on: March 09, 2013, 08:01:27 pm »
Hmm well if more than 1 person thinks it may be that then it may well possibly be. Im sure the garage i go to will know if it is or not. The thing is where im working there isnt much here in terms of somewhere that will get the Sachs stuff i think or can it be bought it easily from a factors of some sort?
Offline camfollower
  • -Receive: 31
« Reply #11 on: March 09, 2013, 08:25:12 pm »
It's not cheap mate :( Because you may as well get the DMF done at the same time being on 86k... probably £600 upwards for parts and labour.
I would defeinitely count out otherthings first... can you get it scanned, perhaps a fuelling issue... although it does sound like the clutch mate.
Do you have a map with handheld device like Bluefin?  Perhaps try knocking it back to standard (therefore reducing the torque) for testing purposes.
Offline Beattie
« Reply #12 on: March 09, 2013, 08:28:38 pm »
I got it mapped at star performance. Where i am is the worst possible place for this to happen...
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #13 on: March 09, 2013, 09:52:20 pm »
Just take it easy and change down more. The clutch will last plenty long enough for you to get it sorted when you're in a better place.
'07 Red manual
Offline Beattie
« Reply #14 on: March 09, 2013, 09:56:59 pm »
Yeah I might get it into a garage and see what they says wrong and if its the clutch then ill
Get it down the road.. Can u drive 80 miles with it in that condition??
