Author Topic: Help Needed !!! - Problem with DSG Gearbox  (Read 2893 times)
Offline GTI-Ross
  • Learning All The Time :)
« on: March 10, 2013, 06:02:02 pm »
Got into the car for the 3rd time today, (no problems first 2 times)  it wont let me me put it into manual mode.  and every mode chage seemed very stiff, ie into reverse, or park.
I then got back home. tried again. i gave it a bit of a thump and it went into Manual mode, but very stiff.
Does it just need a DSG service / new oil or is this more of a problem.....anyone had it before...
Any help would be much appreciated.
« Last Edit: March 11, 2013, 12:11:15 am by GTI-Ross »
Offline GTI-Ross
Re: Help Needed - Problem with DSG Gearbox
« Reply #1 on: March 10, 2013, 07:01:27 pm »
Where's all the VAG veterans when you need them.....
Offline Frodo-anni
  • -Receive: 45
« Reply #2 on: March 10, 2013, 07:27:46 pm »
Do you at any point get any jerky gear changes when it is in 'D'? Or any flashing icons on the dash?
What mileage are you on, has the gearbox oil been changed as per VW instruction ie every 40k?
mk5 GTI Edition 30 DSG No0391
Offline GTI-Ross
« Reply #3 on: March 11, 2013, 12:10:53 am »
Yeah its been service at 40k, seems strange how it just came on.....Really need help
Offline fatty
Re: Help Needed !!! - Problem with DSG Gearbox
« Reply #4 on: March 11, 2013, 03:31:41 am »
maybe take it to a main dealer and ask if their best tech could kindly go out with you in the car for 2 mins to diagnose.
a dealer did it for me once, no cost.
then you should know how to go about getting it sorted.
good luck.
Offline Frodo-anni
  • -Receive: 45
« Reply #5 on: March 11, 2013, 11:16:16 am »
Ring VW White Rose, speak with Ben Smith on service, he should be able to help you, he is also a member on here.
Offline ConeKiller
« Reply #6 on: March 11, 2013, 04:12:55 pm »
I had this problem.
Car wouldnt go in to manual mode, was hard changing between D, N, R etc and sometimes lost all power as if it was in N with all the SDNRP flashing red.
It was the gear selector, cost £450ish i believe to get it sorted.
It wasnt the actual DSG box, just the gear selector module! I can give you the details of who sorted mine out if you are local to Bromley in Kent!
Offline GTI-Ross
« Reply #7 on: March 11, 2013, 04:16:18 pm »
Funnily enough, it seems to have sorted it self out...how strange, got in the car this morning and everything was fine and has been all day...I have no ide what caused it unless it was the cold
Offline ConeKiller
« Reply #8 on: March 11, 2013, 04:23:53 pm »
I would take it easy for a while and see if it happens again, touch wood it wont!!! Mine would do it about twice a week until i got it sorted!
