Poll
What is it you do when you get an error, while loading firmware on RNS510
Download F/W from another site and start again
Re burn the downloaded F/W on to a new DVD
Download F/W from same site again and re burn
Give up
Get someone else to sort it
Author Topic: RNS510 Software Loading Error - What do you do ?  (Read 11761 times)
Offline Kiwi
« on: March 11, 2013, 01:15:00 pm »
As the title says " What do you do if you get a failed upload on your RNS510 "
I'm interested to see what other do, in terms of starting over.
I tend to see this error code a lot (010306), and I'm interested to understand how other's manage it  :happy2:
Kiwi
Re: RNS510 Software Loading Error - What do you do ?
« Reply #1 on: March 11, 2013, 02:18:53 pm »
I'm no expert but have you tried using the SWL recovery disc.
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/firmware/13672-unofficial-272x-software-swl-recovery-cd.html
"SWL recovery CD - in case if your unit is stuck with Gateway Error 202 or some other failure occurs during the upgrade and unit is unable to boot up afterwards. It's based on latest 398x software but can be used to recover RNS-510 running any software version - just insert it and start a new SWL process by pressing Setup + Eject + Info/Mic/whatever top right button. It will try to restore basic coding (including TestMode) and finish SWL, and if your unit is not completely damaged, it will boot up  Support for EU/US/CHN units".
Offline Kiwi
« Reply #2 on: March 11, 2013, 05:01:11 pm »
I'm up and running, with both F/W and Maps, so fingers crossed I don't need the above.
I was more wondering. what people did when this (010306)  appeared on screen 1/4 the way through a firmware install. Hence the reason for the poll  :happy2:
Hoping it'll help others in the long run, if we get a general idea on what everyone does, if and when F/W fails to install  :fighting2:
Offline mikeyfraser
« Reply #3 on: December 24, 2013, 05:17:53 pm »
If got the same problem what do you need to do. I think mines is revision A tho. Where do you find this out?
