Author Topic: Brake Disc Hub Rust (Looking to paint)  (Read 17113 times)
Offline Kalpsn2000
  • -Receive: 56
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Brake Disc Hub Rust (Looking to paint)
« Reply #16 on: March 12, 2013, 01:38:20 pm »
Did that lad use it on his inlet mani!!? :surprised: FFS, must have some serious heat tolerance
Redemption
« Reply #17 on: March 12, 2013, 02:34:05 pm »
Had the calipers and disc hubs on my old Leon FR done with Gloss Black VHT Caliper Paint. Looked great and had no peeling issues etc in the two years I owned it. :happy2:
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #18 on: March 12, 2013, 06:22:55 pm »
I have to get this done too. The laziest option seems to be - brush off loose rust then a lick of Hammerite 'direct to rust'.
If I make a bags of it it's no big deal as I'll have to replace the discs soon enough anyway.
That's what I am currently planning to do :smiley:
Am looking to go silver so would this be ok?
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_158822_langId_-1_categoryId_255239
That's all I did, just sand off the rust and paint straight on. Seemed to work fine.
Offline JoshCupraR
« Reply #19 on: February 09, 2016, 09:16:44 pm »
Did all mine before having them fitted the other day. No pics of the rears but they look like the fronts. I used Zinc 182 Anti rust primer followed by Halfords Black High Temperature Paint. I masked everything off but i was told this is not really needed as the pads will remove any excess paint/spray. 2 coats of each (both sides) and the edges.
Sorry for the thread revival to start with.
Just been searching Google to see about painting the discs using high temp paint and zinc primer and came across this thread. Just hoping you can give me some advice as I've already done pretty much the same as you with the same stuff apart from my primer is just halfords zinc primer.
Did you cure the high temp paint in the oven?
Is the primer safe? Not had any issues with it bubbling under the paint?
Been reading all sorts on google about not supposed to be using primer so hope you can help.
Offline white91
« Reply #20 on: February 09, 2016, 09:40:13 pm »
I did this with hammerite, it hasn't been affected by any high temperatures
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: February 10, 2016, 01:00:16 am »
Excess paint will then foul your pads no???  :signLOL:
Offline JoshCupraR
« Reply #22 on: February 10, 2016, 05:10:44 am »
I've taped up all the braking surfaces and mating/mounting surfaces. More looking for the answer on the primer situation :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #23 on: February 10, 2016, 09:38:12 am »
Same as painting up calipers if you ask me. A heat resistant one and it's all good. Don't know why people go for a rust preventative one when it's not necessary  :congrats:
Whoever said it's not necessary covering the discs  :fighting: you are releasing the brakes then applying so where do you think the paint will go  :signLOL: in the pad face  :stupid:
« Last Edit: February 10, 2016, 01:03:32 pm by r5gtt »
Offline JoshCupraR
« Reply #24 on: February 10, 2016, 10:35:23 am »
Ye I thought that too that's why I spent ages taping up haha.
So with the primer I just thought when I've seen people paint they always seem to use primer so I banged some on. I then went to use the high heat paint and looked at the tin and it says do not use primer. Just hoping to see if it's held up well from the lad I quoted. People say if you bake the primer it will just bubble under the paint :rolleye:
Really hope it doesn't :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #25 on: February 10, 2016, 01:02:16 pm »
Maybe the paint you bought is just like a primer as that's what I thought it was upon first impressions.
Some paints are one coat like perhaps your one but if you used the correct primer then I wouldn't worry too much and fit them on.  :happy2:
  • -Receive: 427
« Reply #26 on: February 10, 2016, 01:10:59 pm »
Holy thread revival.  :wink:
Just do as I mentioned above. Mine were great for the entire time they were on the car. It's a surface being painted, prime it.
Offline JoshCupraR
« Reply #27 on: February 10, 2016, 01:28:26 pm »
Ye I've primed it using zinc primer already, did you bake yours in the oven after the very high temp paint was applied?
  • -Receive: 427
« Reply #28 on: February 10, 2016, 01:59:41 pm »
Yes I did BUT be careful to remember that while baking keep the room well ventilated as the smell given off may cause headaches etc.
Offline JoshCupraR
« Reply #29 on: February 10, 2016, 04:06:42 pm »
Just finished baking them now  :happy2:
Both windows and back door wide open :signLOL: still give me a little headache but there looking good, be cooling down for a while before I can get them out. Thanks for the help tho mate :drinking:
