Author Topic: Mk5/6 standard brakes  (Read 5325 times)
Offline Gtiain
« on: March 11, 2013, 04:55:46 pm »
Are they the same for both the mk5 and mk6 gti's?
Offline daz_pd
  • My VRS
Re: Mk5/6 standard brakes
« Reply #1 on: March 11, 2013, 05:10:03 pm »
front is the same, newer MK6 GTI have a different rear setup (very similar)
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #2 on: March 11, 2013, 05:12:24 pm »
How's it different on the rear mate?  Thought it was a straight swap :(
Offline camfollower
  • -Receive: 31
« Reply #3 on: March 11, 2013, 05:17:42 pm »
Concerned now, as I've jsut bought some cheap MK6 rears of fleabay
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #4 on: March 12, 2013, 07:13:13 pm »
From ETKA, the mk5 GTI has a 282 mm rear disc and the mk6 GTI has a 272 mm rear disc.
The caliper has different codes but I think that they are the same.
Offline camfollower
  • -Receive: 31
« Reply #5 on: March 13, 2013, 10:21:27 am »
Thanks for that.  I'm hoping there won't be an issue clearing the bigger disc :scared:
I went mk6 instead as it's much easier to pickup a low mileage set from the 6.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: March 13, 2013, 12:15:36 pm »
out of interest, what is wrong with the rear brakes on your mk5 to make you change to mk6?
Offline camfollower
  • -Receive: 31
« Reply #7 on: March 13, 2013, 07:09:04 pm »
Knackered matey, they bind all the time been on since 2005... hey guys, if you get a second please take a look at: http://www.mk5golfgti.co.uk/forum/index.php/topic,63348.msg704068.html#msg704068
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #8 on: March 18, 2013, 04:53:19 pm »
Not exactly, mate.  :wink:
Mk.V GTI + Mk.VI GTI up to 2010 > 286 x 12 mm rotors with TRW calipers
Mk.VI GTI from 2010 on + most Sciroccos > 272 x 10 mm rotors with Bosch calipers
They look different and are quite easy to recognize. TRW calipers have a curved yoke, Bosch
calipers have a straight one.
If you still have the first pads: Most TRW calipers came with TRW/Ferodo pads. All the Bosch
calipers I've seen came with Bosch pads which are labeled "Bosch" on the backing plate.
 :drinking:
"You get what you pay for."
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #9 on: March 18, 2013, 05:35:19 pm »
Only looked at 2011/2012 Golf 6 GTI... Didn't know they had different setup...
Offline camfollower
  • -Receive: 31
« Reply #10 on: March 18, 2013, 05:54:41 pm »
You can also use the Mk6 cally with the Mk5 carrier.
