Author Topic: Enabling door lights....  (Read 1974 times)
Offline DanBoy
  • My Ride: Mk5 Golf GT TDI and Škoda Fabia Monte Carlo
« on: March 14, 2013, 11:22:57 am »
Whats needed to be done to enable the door lights so they work?? the garage I spoke to said they could do it but it will take at least a couple of hours coding work, just seeing if this is right??
Unless there is a kind member not too far from Northants who can do it for me.....  :happy2:
Offline skard
  • -Receive: 245
Re: Enabling door lights....
« Reply #1 on: March 14, 2013, 11:33:10 am »
It takes a minute to do each door, you just add a number to the existing coding!
Takes a few hours to do the install plus coding if that's what they meant?
Door cards off and repair wires need fed into the door controller for power, then the light units need installed and wires routed to it.
Offline DanBoy
« Reply #2 on: March 14, 2013, 11:36:01 am »
I've already installed and fitted the wirings just want them switching on.
Offline skard
  • -Receive: 245
« Reply #3 on: March 14, 2013, 11:41:01 am »
Five minutes then
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: March 14, 2013, 11:46:37 am »
Five minutes then
Less then that lol.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: March 14, 2013, 05:12:31 pm »
Find someone local who is on the vcds register
Offline Kalpsn2000
  • -Receive: 56
« Reply #6 on: March 22, 2013, 10:10:32 am »
2 hours for coding! Either they thought you also wanted them fitting or they are behaving like the stealers :fighting:
Offline Simon_2.0t
« Reply #7 on: April 03, 2013, 11:08:43 pm »
Silly questions but why do they not work from standard?
Offline skard
  • -Receive: 245
« Reply #8 on: April 03, 2013, 11:10:37 pm »
They are just reflectors as standard on most mk5's - they need swapped out for bulb units, wired in, then activated by software.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: April 03, 2013, 11:10:50 pm »
because they were not fitted
If they were coded and not fitted it would throw up a fault
Cluster and Key coding
Location Great Yarmouth
Offline Simon_2.0t
« Reply #10 on: April 03, 2013, 11:17:10 pm »
Ahh cool, cheers for clearing up guys.
