Author Topic: Oem Bluetooth required  (Read 1257 times)
Offline micaerin
  • -Given: 19
« on: March 14, 2013, 01:49:18 pm »
Hi guys I'm wanting to install Bluetooth unit to go with my rns510, I have mfsw but only red midline. I have seen. Few on eBay but they specify white dot matrix only. Which unit do I need? I will be using iPhones if that makes a difference.
Thanks in advance.
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Oem Bluetooth required
« Reply #1 on: March 14, 2013, 05:11:09 pm »
Not one of them unless it says can work on rns510
Offline scooba
  • -Given: 18
« Reply #2 on: March 14, 2013, 05:14:17 pm »
Hi , I think you need to speak with eddie nl   he will have them and advise exactly what you require .
Offline micaerin
  • -Given: 19
« Reply #3 on: March 14, 2013, 05:17:21 pm »
I have done, but I know he is a busy man so i will just wait until he does.
Offline Baz300
« Reply #4 on: March 14, 2013, 05:17:40 pm »
I bought a Bluetooth kit from Eddie-NL it works with the RNS510 but does not display on the highline and I can't answer the phone with the steering wheel button but I can still answer the phone through the stereo and stream music through Bluetooth.
I wanted the kit as it was compattable with iPhones, I think you get the phone menu on the highline display if you buy a polar fis box but not 100% sure.
Eddie was also much cheaper then the kits advertised on eBay.
Offline Luka
« Reply #5 on: March 14, 2013, 08:14:34 pm »
Kufatec Fiscon Basic Plus is what you need.
Sold - 2006 Tornado Red GTI 3dr
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #6 on: March 14, 2013, 08:18:44 pm »
If you don't mind not having info on the highline the 5k0 /7ps kit is great
Offline scooba
  • -Given: 18
« Reply #7 on: March 14, 2013, 08:35:39 pm »
I have RNS-510 and red hiline  ,I was advised by Eddie to use Skoda 729b BT Kit as it works with iPhones and  RNS+red dot matrix hi line
Offline micaerin
  • -Given: 19
« Reply #8 on: March 14, 2013, 08:38:41 pm »
I just have midline, so I take it all info comes up on RNS510 display?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #9 on: March 14, 2013, 10:56:03 pm »
It would yes - so best bet in my opinion is a 5k0 kit - I have fitted 3 (and got the plug and play looms for all of them from Ed) and just sources the module box on eBay or similar. Great bit of kit which shows full address book on headunit as well as calls etc
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #10 on: March 15, 2013, 07:28:20 am »
I have the 5k0 kit, works great!
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #11 on: March 16, 2013, 09:24:50 pm »
The 7P6 kit works with RNS/RCD-510 head units but does not show on mid or Highline. I'm currently using the 7P6 kit in my Golf and i cant fault it.
Offline GTI Leeds
« Reply #12 on: March 16, 2013, 11:31:06 pm »
Anyone any idea what I need to get it working in the MK6 GTD?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #13 on: March 17, 2013, 09:36:25 am »
5k0 should work
Offline tonto83
« Reply #14 on: March 17, 2013, 10:03:03 am »
I have the midline display, rns and the kufatec basic plus.  I answer and dial via the touch screen.  It's an excellent piece of kit.
