Author Topic: "Schroth Quickfit removable 4-point harness" By Tony Danza  (Read 44174 times)
Re: "Schroth Quickfit removable 4-point harness" By Tony Danza
« Reply #15 on: July 23, 2009, 03:22:04 pm »
This is the harness I have in the Cupra :D
98€ fitted.  Need to turn off the seatbelt warning chime with vag com though, till then i have my seat belt plugged in going around the back of my seat...
Get on well with this
« Last Edit: July 23, 2009, 03:25:36 pm by Tfsi_Mike »
Offline tony_danza
  • -Receive: 112
« Reply #16 on: July 23, 2009, 03:48:13 pm »
Is yours just a normal Schroth 4-pointer? As this actually clips into the existing seatbelt buckle, so no need for the vagcom mod/belt work-a-round.
Sideways yo!
« Reply #17 on: July 23, 2009, 04:43:34 pm »
No its the 3point with a clip at the back allowing the rear strap to drop to allow rear passenger.  Doesn't use any of the existing seatbelt buckles...
« Reply #18 on: July 23, 2009, 06:28:16 pm »
Yep, you're absolutely right, Robin. Yours have the guide holes for a very good reason, to keep the straps on your shoulders.
....It would be rude not to use them! :grin:
I would only use these on the track no matter what seat I had, mainly for the reason on certain types of junction you have to lean forward to see. This would mean loosening the belts to enable you to move and if you were to be shunted, you wouldn't be safe.
....Very good point re some road junctions. When I recently drove the road-legal track GTI (pic in my sig) with full harness, I had two problems: 1) The sides of the Recaro Pole Positions blocking my view, and 2) Betty Swollox from the groin tightness. I still absolutely loved driving her on the road though!
I find that side>rear visibility with my Recaros is greatly improved in comparison with my stock GTI driving seat.
You MUST guide them through the headrest poles to ensure they don't/can't slip over the shoulders of the seat. Doing this makes them no different to the style of seat below, and to be fair the headrest should be raised for most people anyway to work properly.
....The headrest SHOULD be raised as you say, but I wonder how many people's actually are?
If it all were to go wrong though, I think a bit of belt marking on the neck would pale into insignificance compared to everything else.
.... :laugh: - Agreed!
^^^^ Now THAT is a great fast road car seat!
Offline tony_danza
  • -Receive: 112
« Reply #19 on: July 23, 2009, 08:43:31 pm »
Group Buy open kiddywinks!!
Fill yer boots.
Link
Sideways yo!
Offline tony_danza
  • -Receive: 112
« Reply #20 on: July 27, 2009, 09:42:36 pm »
Picsies, took 10 minutes to install. Car's now stripped and ready for Friday.
Oh, and a new rear badge. OEM FTW.
Sideways yo!
« Reply #21 on: July 27, 2009, 09:48:48 pm »
Me Likey.  :happy2:
May even change the colour of mine to the same, i have a thing for yellow at the moment.  :rolleye:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #22 on: July 27, 2009, 10:27:31 pm »
oooooo they look OEM++  :happy2:
non electric lumbar support ???? eh?
Red ED35 5dr DSG
BLOG | BUILD
« Reply #23 on: September 11, 2009, 02:36:34 pm »
....Are those 'star' bolts already on the car?
And what rating should they be tightened to?
Cheers :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #24 on: September 11, 2009, 02:56:07 pm »
Yes, they're the existing seatbelt anchor points - can't remember the torque settings though, sorry. TTS should know.
Sideways yo!
« Reply #25 on: September 11, 2009, 03:51:09 pm »
Thanks, Mike :happy2:
Abi is going to contact Schroth to find out about torque settings but we are collectively thinking that as it's not stated in the German instructions (as far as we can see), then it's not critical. Probably just tighten with human arm until it won't go any further without using extra force or stripping the bolt - Rather like the Recaro seats on the floor.
@ TC - For us guys with Recaro's, it's best to undo all the quick release parts and fold and feed through the Recaro slots from the rear. :smiley:
Offline tony_danza
  • -Receive: 112
« Reply #26 on: September 11, 2009, 04:09:16 pm »
I checked it once and basically it's pretty much as tight as you can get it with a rachet - I've had the seats in and out that many times now I just do it up as hard as I can. You'll not strip the thread on those bad boys!
You'll need to bend the buckle for the front one, vice and a set of grips will do the trick. It tells you how to do it in the instructions.
Sideways yo!
« Reply #27 on: September 11, 2009, 04:34:07 pm »
Ah, I wondered what that bending illustration was all about.
I haven't got the appropriate tools to install so I'll have to visit my mate who reupholstered my Recaro's or wait til my next visit to VWR. Or....If you could tell me which size 'star' bolt bit to get I could buy one.
Offline tony_danza
  • -Receive: 112
« Reply #28 on: September 11, 2009, 04:45:12 pm »
Tools required and a guide for the back seat out here
Front one, simply pull the carpet back from the sill cover and it's towards the front of the slider rail - 6" extention will help here.
Sideways yo!
« Reply #29 on: September 11, 2009, 06:02:52 pm »
Brilliant, Mike!  :drinking:
