Author Topic: "Schroth Quickfit removable 4-point harness" By Tony Danza  (Read 44232 times)
Offline tony_danza
  • -Receive: 112
Re: "Schroth Quickfit removable 4-point harness" By Tony Danza
« Reply #75 on: November 19, 2009, 03:08:46 pm »
Check out the Instructions booklet > page 19 > Vehicle Reference List > VW Golf V - "Only with Approved After Market Seats". That doesn't look like good news for oem seats and puts a question mark over the Recaro's even though they were a limited factory option.
Link : - http://www.schrothracing.com/docs/VW_&_Audi_Quick_Fit_Instructions.pdf
Robin - if you look up, there's a link from Recaro stating your seats are approved for use with a 4-point harness......
Sideways yo!
« Reply #76 on: November 19, 2009, 03:19:51 pm »
....Is the Recaro seat as TC's and mine one of these? : -
Keiper Recaro:
Orthopäd, Designer Touring, Idealsitz SR, Idealsitz L/LX/LS 84, Idealsitz CS84, CSE, T-Line, Designer Sport, C-Classic, TX, N, LS, CT, Variomed, A 8, Modular, Ergomed, IS 2000 Style, D&W-Sitze
Offline tony_danza
  • -Receive: 112
« Reply #77 on: November 19, 2009, 03:26:57 pm »
Its known as a CS, so I can only assume a CSE is the version provided to the likes of VAG/BMW/Ford/Renault.
Sideways yo!
« Reply #78 on: November 19, 2009, 03:35:15 pm »
Also, forgot to mention, make sure the lap section is nice and low in position - you don't want to submarine out of the seat in the event of a crash. Should be where a normal 3 pointer sits, under the belly!!
....Should be positioned as you and Schroth's Instructions rightly say. The "ASM" in the Schroth QuickFit title stands for Anti Submarining Mechanism. I've now seen a vid with crash dummies which shows how the Schroth ASM works.
« Reply #79 on: November 19, 2009, 03:37:44 pm »
My link has opened a can of worms  :rolleye:
Offline tony_danza
  • -Receive: 112
« Reply #80 on: November 19, 2009, 03:45:13 pm »
I can see if now...
Glasses on end of nose, printed off on A3 and highlighter pen giving it six-nowt.
/pulling legs.
Sideways yo!
« Reply #81 on: November 19, 2009, 04:02:24 pm »
....Recaro CSE has user operable electric settings and memory and looks different to both ours.
The Recaro web site won't give a direct link to the page so: HOME Original Equipment >>  Products >>  All vehicles >>  VW Golf V GTI >> and our Mk5 GTI has what Recaro call "cccls" as one of its many oem products for car manufacturers. The cccls is pictured as the same as mine and TC's and not the standard oem GTI seat. However I can find no other reference anywhere in cyberspace which relates to "Recaro cccls".
Looking at the various Recaro seat types which Schroth approve, I'm fairly confident we don't have a problem.
Offline animal
  • .:R32
« Reply #82 on: May 24, 2010, 01:35:44 pm »
I have posted this else where in a current, relevant post. But, I thought it important to capture it here. It would seem my early concerns weren't entirely un-founded after all. I noticed this on my lower B-pillar (inside the door-shut) at the weekend (I have factory fitted Recaros):
« Reply #83 on: May 24, 2010, 02:31:51 pm »
I still think it depends on the angle of the straps. The Schroth info shows it and it's already been posted in this thread IIRC. The point is that the Schroth Quikfit uses extra floor anchors (and it's TUV approved).
That label illustration shows the Recaro seat front, not back, and the Schroth male 'tabs' run in the other opposite direction.
Furthermore, I translate that label as an instruction to feed the 'tabs' in the direction which the Schroth does.
I would even go as far as suggesting that this label indicates a support of the use of such safety belts.
« Last Edit: May 24, 2010, 02:35:36 pm by RedRobin »
Offline animal
  • .:R32
« Reply #84 on: May 24, 2010, 03:28:36 pm »
Robin, a big part of my job is designing pictograms for user instructions and making things as simple and as clear cut as possible graphically, whilst being technically correct and leaving little scope for mis-interpretation. This is without any doubt a warning sticker. IM(professional)O, a picto of a bucket seat with a big red cross through it leave very little doubt as to what message VW are trying to convey. My technical specialist colleagues agree. This picto is not about the type of harness, it's about the inherent weakness of the seat due to it being designed to articulate forward.
I'm not saying to you shouldn't use your harness but clearly VW don't endorse it. I have simply posted this to inform others considering harnesses who may have also retrofitted these same seats and therefore are unaware of VW's official position on the matter.
« Reply #85 on: May 24, 2010, 03:59:32 pm »
a big red cross says under no terms fit a harness pure and simple as these seats are more for show the are not race seats  :smiley:
Offline Poppa Dom
« Reply #86 on: May 24, 2010, 05:41:37 pm »
Perhaps we should do some in house forum testing?
Offline Janner_Sy
  • -Receive: 113
« Reply #87 on: May 24, 2010, 07:12:14 pm »
sounds dodgy to me.  very dodgy. that warning pic is pretty self explanatory as well, and you could be pretty certain it is not belt specific
« Reply #88 on: May 24, 2010, 07:56:09 pm »
Yes, as I just posted in the other thread, it's the tilt release where the potential problem is.
Offline QD MBE
  • -Receive: 102
« Reply #89 on: May 24, 2010, 08:06:44 pm »
