Author Topic: RNS 510 v9 Delay  (Read 6634 times)
Offline Demonter
Re: RNS 510 v9 Delay
« Reply #15 on: March 18, 2013, 06:14:53 pm »
The new features are :-
Voice Control (requires microphone – see Volkswagen RNS 510 Microphone Connection for voice control)
NEW hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
NEW Compass
NEW POI- see Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
NEW Languages – Arabic,  Russian, Turkish and Polish
Speed Limit Display
Stability Improvements
Faster Startup (this has been improved on 2720)
Display OPS and RVC at the same time
SDHC 32 GB Support (HW04 and above)
Display Off on extras tab
Climatronic control if approriate climatronic fitted
Clock display if RNS 510 swtiched off
Excluded roads (under route options)
GPS coordinates entry
Additional adjustments for video
Larger RVC screen with transparent menus at the side
these are the new features for 3810 sw? cant i make 4120?
you said here http://www.mk5golfgti.co.uk/forum/index.php/topic,63424.0.html that u had probs with it, such as not be able to enter postcodes as on the move?
well im in sweden so im afraid no one can help me in person. i will download this one then http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html 381x if you say its good.
should I do SWL Recovery disc ?
« Reply #16 on: March 18, 2013, 10:57:02 pm »
IMO you should have one available just in case something goes wrong during the flash.
Offline Kiwi
« Reply #17 on: March 19, 2013, 10:54:22 am »
NEW Compass
Speed Limit Display
I'd go 3810a Firmware, which is what I've re done and now can get Postcodes entered on the move and Radio Text
As said, you should download SWL Recovery, just in case
Offline Demonter
« Reply #18 on: March 25, 2013, 06:34:48 pm »
 well dudes,ive install 3810 version of a software and it was positive. now in secret menu it says its D version of a unit,it was b before as u can see in picture above in my previous post.
the thing is that this sw installation deleted my maps haha :happy2:
now to install new maps or  recovery disc can fix the problem?
plus when system is offline for a longer period it takes about 10-12seconds for the system to start up from start up vw logo. and when the system is on when i press settings it says system is starting up (5seconds cca). before it was instant.
f*ck my life
« Last Edit: March 25, 2013, 08:09:05 pm by Demonter »
Offline Demonter
« Reply #19 on: March 26, 2013, 06:54:41 am »
anyone?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #20 on: March 26, 2013, 08:35:25 am »
it isnt a problem, when updating from a b unit, it changes it to a D.
i did MK6Greg's update last night and his changed too.
Just load the maps and you will be ok.
Sometimes if using a modified firmware to prevent battery drain issues, there are some things that take longer to start up. Its nothing you should be worried about.
If its something thats really bugging you, then update the canbus and install a higher firmware like 4120,
Offline Demonter
« Reply #21 on: March 26, 2013, 08:55:47 am »
ok can bus is gateway fix that is in sticky on the first page?
