Author Topic: Polar FIS+ - Firmware Update v0.3.6 available  (Read 675 times)
« on: March 15, 2013, 08:08:17 pm »
***** Improvements / Update description for RED cluster *****
  • Solved issue that causes that configuration was not stored and sometimes user configuration was resetted
  • Solved issue with automatic closing function that causes malfuntion of the windows and battery drainage in some vehicles
  • From 0.3.5 firmware, the configuration of the steering wheel buttons change and each button can be configured independent, so if after update you can not switch the screens in the Polar FIS main menu, go to configuration menu and SCREEN - POLAR KEYS and configure each key with the desired function
***** Improvements / Update description for WHITE and COLOR cluster *****
  • Solved problem that causes to dissapear TELEPHONE menu after switch off Polar FIS
For installation of this update please use ActiveX from our official web www.auto-polar.com (Update Zone)
Offline Cupra R
  • -Given: 18
Re: Polar FIS+ - Firmware Update v0.3.6 available
« Reply #1 on: March 15, 2013, 09:24:47 pm »
I'll give this a whirl tomorrow.
