Author Topic: Fitting a catback milltek  (Read 3867 times)
Offline darrens
« on: July 22, 2009, 10:40:12 pm »
I am close to buying a catback milltek and will be getting a friend to help fit it.
If there anything else I need to get such as gaskets or is a straight replacement?
Please excuse my lack of technical knowledge, I'm learning as I go!
Re: Fitting a catback milltek
« Reply #1 on: July 22, 2009, 10:51:05 pm »
Make sure it comes with the reducer to mate it up to the existing OEM cat. :wink:
Offline darrens
« Reply #2 on: July 22, 2009, 11:12:10 pm »
Yip its there (I hope!)
How many separate parts should come with it?
« Last Edit: July 22, 2009, 11:16:11 pm by darrens »
« Reply #3 on: July 23, 2009, 07:49:29 am »
3. Back box, centre section and reducer.
« Reply #4 on: July 23, 2009, 09:49:56 am »
ive got a spare reducer knocking around somewhere, youll probably get one anyways
Offline darrens
« Reply #5 on: July 23, 2009, 10:18:48 am »
Thanks, I will let you know if I don't get one with the exhaust but hopefully it will all be there!
The guy who is fitting it says I will need some mikalor clamps.  Are these usually included with the exhaust or will I need to source some and if so what size?
« Reply #6 on: July 23, 2009, 10:39:36 am »
they will come with the exhaust, well...they do with a miltek. all the necessary fitting gubbins come in the box
Offline H DUBS
« Reply #7 on: July 23, 2009, 11:52:31 am »
Hi Darren,
Got my Milltek Cat Back delivered yesterday and I can confirm that it comes with all the above. 3 x Clamps. Reducer. 2 x Sections.
Hope this helps.
Offline darrens
« Reply #8 on: July 23, 2009, 12:06:48 pm »
Cheers  :happy2:
Offline H DUBS
« Reply #9 on: July 23, 2009, 12:54:18 pm »
Did your mate say anything about needing exhaust paste between the sections?
Offline darrens
« Reply #10 on: July 23, 2009, 02:03:38 pm »
No, is this needed?
Offline H DUBS
« Reply #11 on: July 23, 2009, 02:05:17 pm »
I'm not too sure mate. I'm hoping someone on here can shed some light. I'm also fitting it myself this weekend.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #12 on: July 24, 2009, 05:49:35 pm »
Use a silicone sealant instead, which will not dry to powder, crack, fall out and cause leaks.
#1493
