Author Topic: Stopping the rain sensing wipers  (Read 4581 times)
Offline Beeps
« on: March 18, 2013, 09:04:56 pm »
To stop the manic rain-sensing double-speed wipers when all you wanted was a delayed wipe - disconnect the sensor.
Prize apart the black clam shells behind the mirror. At the bottom of the glass-mount, pull down the mirror's power plug and pull the mirror down. Moving the top tube a bit gives access to the rain-sensor plug, pull it out.
Rebuild and you have nice, calm, normal delayed wipers.
Offline karl210
Re: Stopping the rain sensing wipers
« Reply #1 on: March 18, 2013, 11:26:55 pm »
Glad im not the only one that wants to set them on fire. Sometimes they work fine but most of the time u look an absoloute t*t sat at traffic lights with them going off on one. This i will be doing.
Offline john87
  • -Receive: 53
« Reply #2 on: March 18, 2013, 11:59:11 pm »
Mine are pretty accurate 90% of the time! Being a 2008 though I think it has a revised sensor...
Offline andybon
« Reply #3 on: March 19, 2013, 08:50:30 am »
Mine must have been the stoner or the dole queue one. Only works when you give it a good prod!
How hard can it be?
Offline Trev.
« Reply #4 on: March 19, 2013, 10:15:47 am »
Thank f*ck! hate the damn things!
Offline OSB
  • -Given: 32
« Reply #5 on: March 20, 2013, 07:45:34 am »
I really like mine! One of the best toys I've got on the car. Works when its raining, stops when its not ....
Offline john87
  • -Receive: 53
« Reply #6 on: March 21, 2013, 10:00:28 am »
...and mines rarely do a 'rogue' wipe when the windscreen is bone dry. My civic had auto wipers and it used to do at least one 'dry wipe' every day if they were switched on  :scared:
Offline Beeps
« Reply #7 on: December 14, 2013, 11:22:00 am »
This works on the Mk6 as well
Offline SkyJawa
« Reply #8 on: December 14, 2013, 11:39:32 am »
Work fine on our 2005......
Offline SRC
  • -Receive: 27
« Reply #9 on: December 14, 2013, 11:55:26 am »
My late 56 plate works well, so I'll count my blessings.  Glad you found a cure for yours, though.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline xjay1337
  • -Receive: 377
« Reply #10 on: December 14, 2013, 04:30:59 pm »
I had no problems with the wipers on either of my Golfs (the GTI is my second).
If you don't like them simply use Vagcom to disable them or you can SKIP the "intermittent/auto" setting and use them manually or on regular speed.
Offline Gide76
« Reply #11 on: December 14, 2013, 05:29:41 pm »
Mine work well 99.9% of time but sometimes I find them a little slow to react although the massive saving in the effort of using my right arm negates any lack of visibility.
Oddly used to have the odd nearly wipe on my 8p a3 sportback even though it didn't have auto wipers!
Offline Beeps
« Reply #12 on: December 14, 2013, 09:24:57 pm »
Xjay1337, The reason I had to pull the plug is I could not find an option on my Vagcom to turn them off - how do you do it?
Offline xjay1337
  • -Receive: 377
« Reply #13 on: December 14, 2013, 09:33:22 pm »
There is a checkbox somewhere I believe, auto sensing wipers or something.  :party:
