Author Topic: Engine Oil expiry???  (Read 898 times)
Offline Jussa
  • Bicester
« on: March 19, 2013, 05:08:06 pm »
Does Castrol Edge 5W-30 have an expiry date?
I've found an original 4L container outside in my shed that's been there for about 2 years, it's been opened previously but sealed tightly since then.
It still has around 2 litres in it, can I still use it?  :confused:
Re: Engine Oil expiry???
« Reply #1 on: March 19, 2013, 05:18:47 pm »
It should be fine as it's been in a sealed container and it isn't hydroscopic.
Offline Jussa
  • Bicester
« Reply #2 on: March 19, 2013, 05:22:44 pm »
Hydroscopic WTF?  :confused:
I must have been sleeping at school  :signLOL:
AA
« Reply #3 on: March 19, 2013, 05:24:33 pm »
Its already 50 million years old by the time you bought it so a couple of more years wont matter too much :signLOL:
Offline Adam-golf
  • Derv!
« Reply #4 on: March 19, 2013, 05:41:12 pm »
Does it actually have an expiry date then?
« Reply #5 on: March 19, 2013, 05:45:25 pm »
Hydroscopic = doesn't absorb water. Brake fluid is hydroscopic!
btw it's not 50 million years old as it's synthetic.
Offline flashp
  • -Receive: 65
« Reply #6 on: March 19, 2013, 11:26:07 pm »
Hydroscopic = doesn't absorb water (this would be Hydrophobic). Brake fluid is hydroscopic!
Engine oil is actually Hygroscopic but to a lesser degree than brake fluid. It means it takes in moisture from the atmosphere. Can you be sure that condensation has never formed in the can through temperature cycling in the shed?
Cost of oil 'vs' value of engine...I'd bin it. It may well be OK but you'll know that once you've got away with it, not before.
Gone but not forgotten :-)
Offline Jussa
  • Bicester
« Reply #7 on: March 19, 2013, 11:40:14 pm »
It's not in a can, it's in that 4 litre plastic container.
I can't guarantee there hasn't been condensation as its been outside for ages - not sure how condensation would form inside a sealed container  :confused:
But you're probably right, it's not worth any risk, but still throwing away a good £15 worth of oil does hurt  :sick:
Offline andygo
« Reply #8 on: March 20, 2013, 11:45:24 am »
It will be fine. Any moisture will evaporate off anyway. Its not like it will have gone from 1 litre to 2 litres ffs!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: March 20, 2013, 05:07:29 pm »
Will be fine, won't do any harm. Don't be too precious about it IMHO  :grin:
Even if there was a bit of moisture, once in your engine and at 95 degrees+ it will soon evaporate  :happy2:
My mate once put a fair amount of fairy liquid into a Peugeot engine and it was fine.
Gray
