Author Topic: Common issues for newbies  (Read 21712 times)
Offline alexmccabe
    • Alex McCabe
« on: March 20, 2013, 09:38:24 am »
Replacement parts after purchasing
A guide on what the DV and PCV do and the problems they cause:
http://www.mk5golfgti.co.uk/forum/index.php?topic=44709.0
The old DV's that need replacing:
The new ones to replace with:
ReplacementPart Numbers:
DV Revision G - Part number  06F 145 710 G
DV Revision D - Part number  06H 145 710 D
Note: you can choose either of these, there are advantages and disadvantages to both.
PCV Revision R - Part number  06F 129 101 R
Note: There may be variations depending on your build year and engine. Ring the dealer and confirm that it is the correct part for your car.
Cam-Follower - Part Number 06D 109 309 C
You will need to replace the cam-follower after 80-100k miles. http://www.mk5golfgti.co.uk/forum/index.php/topic,1162.0.html
Thread on Ignition Coil Recall: http://www.mk5golfgti.co.uk/forum/index.php/topic,75393.msg798795.html
VW are currently doing an Ignition Coil recall on older registered cars. Give your local dealers a call and give them your plate. They will be able to tell you if you are eligible. Definitely worth doing.
And here is a thread that lists a whole load of how-to guides, that is very useful: http://www.mk5golfgti.co.uk/forum/index.php/topic,52731.0.html
Front Wing rust under warranty
If you are unlucky enough to have rust on your front wing, VW will sometimes sort it for you under warranty. They offer a 12 year paint warranty on these cars, and if you have rust on your wings with the original factory paint, you could very well be in luck. Bear in mind, they are extremely hard to get done and you may end up having to pay for some of it yourself.
There is a whole thread discussing the various degrees of success that people have had on this here: http://www.mk5golfgti.co.uk/forum/index.php/topic,48873.0.html
3-Door Broken Seat Slider (the seat does not slide when the top handle is pulled)
There is a little clip at the back of the seat, behind the flap. This clip is made of plastic and flimsy, but easy to replace. More details on how to do this can be found here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,37400.0.html
Useful replacements
Spark Plugs: NGK Iridium 8. These come highly recommended on the forum, and work throughout all stages of tuning.
If your air-con has stopped worked, there is a chance that the pressure sensor/switch (same part, different people call it by different names) has broken.
Aircon pressure switch: 1K0 959 126 E - £59.80
Seal: 8E0 260 749 C - £0.77
Not a usual mod, but a thread on adding the BlueMotion parts to your car: http://www.mk5golfgti.co.uk/forum/index.php/topic,22986.0.html
Full VW Golf Engine under tray
(x1) 1K0 825 237 P Undertray £26.24
(x3) 1K0 825 951 Hex headed bolt (Combi) 80p each (M6X20 hex socket head bolt)
Rear axle cover as fitted to VW Golf bluemotion
(x1) 1K0 501 713 D Trim for Rear Axle £25.03
(x1) 1K0 501 682 Retaining bracket £1.67
(x1) N 905 483 05 Retaining bolt 47p
(x1) N 901 838 02 Retaining bolt £1.63
Rear arm covers from Audi TT
(x1) 1K0 511 539 E Stone chip Guard £4.69
(x1) 1K0 511 540 C Stone Chip Guard £5.91
(x4) 8E0 825 267 A spreader rivet 10p each
(x2) 1K0 609 734 C brake cable clamp 76p each
(x2) N 102 854 02 Bolt 18p each
If I recall correctly, there are some limitations to doing this, one of them being an after market exhaust to fit some parts. Give the thread a read for a better understanding. There is apparently and fuel economy increase. I have been planning to do this, but funds have been tight lately.
If anyone has anything that other newbies should look out for, let me know and I will add it to here.
« Last Edit: May 05, 2017, 08:29:48 pm by alexmccabe »
MK5 Golf GTi 197BHP Tornado Red
Offline Trev.
Re: Common issues for newbies
« Reply #1 on: March 20, 2013, 03:48:58 pm »
I agree this would be good, i spent ages looking through the forum to find them!
Offline grey golfster
  • -Given: 79
« Reply #2 on: June 02, 2014, 08:00:06 am »
+1.
Fantastic resource here..thanks fellas.
A newbie shortcut to "critical" items would be a real help.
Took me a while to digest info.
DV, cam follower etc all now done with help n advice off here.
Offline akbarirfan
  • -Given: 81
« Reply #3 on: June 02, 2014, 04:45:44 pm »
Also Coil pack recall..
Offline alexmccabe
    • Alex McCabe
« Reply #4 on: June 03, 2014, 02:32:19 pm »
Yes definitely, this is something I only found out about a few months ago myself.
Offline SurreyED30
« Reply #5 on: June 03, 2014, 08:45:49 pm »
This would be so much easier for newbs and also will save the " use the search bar durr " comments  :laugh: with this they'll be able to start changing and learning about parts that need to be changed to keep on top of things and keep everything running sweat before They read the 100's of threads on tuning your GTi and slashing your bank balance by a %  :signLOL:
I think this newbs thread  is a great idea, Got my vote  :happy2:
Offline alexmccabe
    • Alex McCabe
« Reply #6 on: June 04, 2014, 10:55:41 am »
I have updated the thread with a lot of useful information, I hope it helps people.
Offline SurreyED30
« Reply #7 on: June 04, 2014, 04:08:56 pm »
now this has helped me as KFC lakeside ripped out my belly pan and im after a new one  :happy2:
Offline paulw123
  • -Receive: 47
« Reply #8 on: June 04, 2014, 05:54:32 pm »
how about the new ECS ally one?
http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/News/VW_MKV_GTI_ECS_Tuning_Street_Shield_Aluminum_Skid_Plate_2006_2007_2008_2009/
Offline howie1987
  • -Given: 92
  • -Receive: 21
Re:
« Reply #9 on: June 04, 2014, 06:27:28 pm »
I should of actually looked here before starting a thread.
Offline SurreyED30
« Reply #10 on: June 04, 2014, 10:22:30 pm »
Quite pricey mate, will have to add import and all that extra cost on top aswell as probably a Month shipping. Thanks you mate  :happy2: :happy2:
« Last Edit: June 05, 2014, 08:26:43 am by SurreyED30 »
Offline alexmccabe
    • Alex McCabe
« Reply #11 on: June 05, 2014, 05:17:20 pm »
Modified
Updated PCV part number
Added Air-con pressure switch
It would be cool if this thread could be moved to a more appropriate section too?
Offline usmangti
« Reply #12 on: June 05, 2014, 05:31:22 pm »
Excellent idea. Was defo lacking when I joined the site, could also be used as a buyers guide to check these areas.
How about the rusty front wings?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=cj32atfmd7bpf1qqniaih88b07&/topic,19740.0.html
« Reply #13 on: June 05, 2014, 05:49:26 pm »
Modified
Good idea... will move it to the How to/troubleshooting area in a bit.
Offline SurreyED30
« Reply #14 on: June 05, 2014, 09:12:16 pm »
