Author Topic: Poor starting relating to the priming fuel pump??  (Read 6464 times)
Offline f00glee
Re: Poor starting relating to the priming fuel pump??
« Reply #15 on: January 03, 2018, 10:28:43 pm »
I have the same issue.
4 page thread about it here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,114226.0.html
Current:
Mk6 R, Tornado Red, 5-door, '13.
Previous:
Mk5 GTI, Tornado Red, 3-door, '06, R-tech Stage "1+"
« Reply #16 on: January 04, 2018, 10:05:05 am »
The only difference between the old and new pumps is the old one has a lid, the new one doesn't.    The early pumps could overheat on long journeys, especially if the fuel level is 1/4 or lower.
You could fire the parts cannon at the car and replace it, but it makes sense to buy a cheap fuel pressure tester from Amazon and see what pressure you're seeing when you open the door, and/or pulsing the ignition a few times.
I'm pretty sure the engine starts and runs from the in-tank pump only until the ECU commands high pressure from the mechanical pump, therefore there can be a few seconds of crap running if the in-tank is on it's way out.   The high pressure pump can't be outruled either.
