Author Topic: Has anyone changed the LPFP at Stage 2+?  (Read 17893 times)
Re: Has anyone changed the LPFP at Stage 2+?
« Reply #15 on: March 21, 2013, 08:08:13 pm »
Not yet, I would like to have some trimming or more flocking done
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #16 on: March 21, 2013, 08:42:28 pm »
I was under the impression that these literally run from a 12V source and pump at a really low rate to the the engine, ive spoken to a vag master tech who wasn't able to guarantee it but does doubt there is very very very little point in upgrading it, only benefit maybe prime faster slightly but can't see there being an increase in performance from it, it just delivers to the engine and doesnt run under massive pressure like a hpfp,
only way I can think of it is like maybe upgrading your washer pump  :signLOL:
he couldn't guarantee it too me and im no expert but id want too see dyno results and data logs before I buy one....and soon  :laugh: I need a new one
www.distinctdetailing.co.uk
« Reply #17 on: March 21, 2013, 08:45:56 pm »
I dont expect to see any gains.  Some people have claimed gains.
I did it because the lpfp works hard to supply the engine, the TTRS pump will be under much less stress which long term for me means reliability. Also future proofs for possible BT plans as it provides lots more headroom  :innocent:
Offline vRSAlex
  • -Receive: 253
« Reply #18 on: March 21, 2013, 09:32:01 pm »
Master tech!  You mean apprentice.
Variable load pump controlled by its own ecu.
All the logs are in my build thread.  Can flow and hold much higher pressure at lower load.  Basically gives the hpfp more help allowing it to work under less strain.  After fitting I noticed more mid range and top end grunt.  Hpfp pressure was also more stable.
Follow AKS tuning on Facebook
« Reply #19 on: March 21, 2013, 09:33:07 pm »
Sweeeeeeet  :smiley:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #20 on: March 21, 2013, 10:45:31 pm »
might put the ttrs lpfp in then and the apr hpfp at same time and get rid of the autotech internals
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #21 on: March 21, 2013, 11:04:02 pm »
How straight forward would this be Alex??  Variable load pump controlled by its own ecu
Silver is the way !
Offline vRSAlex
  • -Receive: 253
« Reply #22 on: March 21, 2013, 11:57:14 pm »
All you need is a pump and a blanking plug when running it in a fwd car.   Ive had some cnc plugs made for the job.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #23 on: March 22, 2013, 12:35:49 am »
Pitty I had not found this out sooner, as I have just fitted an up to date LPFP
Silver is the way !
Offline martziniuk
« Reply #24 on: March 22, 2013, 10:20:23 am »
I've been looking into this too. What blocks are used to log lpfp actual and requested.
Offline gazbutS3
« Reply #25 on: March 22, 2013, 10:40:24 am »
Is the TTRS/RS3 lpfp a direct fit into the S3 then Alex?
« Reply #26 on: March 22, 2013, 01:51:04 pm »
231   :smiley:
« Reply #27 on: March 22, 2013, 02:02:42 pm »
Duty cycle too?
« Reply #28 on: March 22, 2013, 02:19:53 pm »
Duty cycle too?
That block also gives % load.
Offline edd666999
  • -Receive: 89
« Reply #29 on: March 22, 2013, 05:22:27 pm »
whats the part number im asking audi for?  :smiley:
