Author Topic: Key fob query ?  (Read 2349 times)
Offline 182_blue
  • -Receive: 54
Key fob query ?
« on: July 24, 2009, 08:33:24 am »
My friend at work says his wifes spare key now wont unlock the car with the plip part, using the blade he can unlock the car and he can start the car using the blade, but he cant open the doors using the plip (or lock using plip), he has changed the battery and that didnt help ?, anything else to try ?, will the fob need reprogramming after a battery change ? (i heard it can be reset by leaving key in ignition ?
cheers
Offline Cooper
Re: Key fob query ?
« Reply #1 on: July 24, 2009, 08:50:31 am »
I had this when the battery ran out in one of my keys, just took it down to the dealer and they reprogrammed, they said it was very common when the batteries run out and did it for free as it was still under warranty
C63
SQ5
WILLZIE
Re: Key fob query ?
« Reply #2 on: July 24, 2009, 10:19:22 am »
Will the key need re-programing every time the battery goes flat then?
If so, thats goina be expensive after warranty!? :scared:
Offline icenutter
Re: Key fob query ?
« Reply #3 on: July 24, 2009, 10:40:47 am »
Don't confuse synchronising the key with setting the immobiliser.  Sychronising is easy, and you do this after changing the battery or pressing the button too many times away from the car
http://uk-mkivs.net/forums/p/60202/451448.aspx#451448
Programming the immobiliser (in practice) has to be done by the dealer.
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
Offline 182_blue
  • -Receive: 54
Re: Key fob query ?
« Reply #4 on: July 24, 2009, 12:36:43 pm »
so you need to do this (in the link) if the battery has gone?
Offline Caz
  • Golf GT Sport TDi - called Gordon
Re: Key fob query ?
« Reply #5 on: July 24, 2009, 12:47:32 pm »
change battery,
if that dont work, it will ned re programming. (0.5 at dealer)
".. in the process of learning the vw service trade!"
Offline icenutter
Re: Key fob query ?
« Reply #6 on: July 24, 2009, 05:05:55 pm »
I believe so.
