Author Topic: Installing MDI Kit - But have error 03138  (Read 8008 times)
Offline Kiwi
« on: March 21, 2013, 07:11:09 pm »
Hi All,
The MDI shows up on my RNS510, and controls my iPhone and even charges it, but \i have no sound coming from it. The Radio get radio and plays that fine, playing music via bluetooth is also fine.
I have Vag Com it and this is what I get
03138 - Input AUX IN
03138 - Input AUX IN: Open or Short to Ground
Possible Symptoms
Auxiliary Input not working
Possible Causes
Wiring and/or Connector(s) from/to Auxiliary Input (Audio Jack/TRS Connector) faulty
Possible Solutions
Check Wiring and/or Connector(s) from/to Auxiliary Input (Audio Jack/TRS Connector)
Check/Replace Auxiliary Input (Audio Jack/TRS Connector)
Anyone care to explain in plan english ?
Kiwi
Offline Kiwi
Re: Installing MDI Kit - But have error 03138
« Reply #1 on: March 21, 2013, 07:12:32 pm »
Thursday,21,March,2013,19:11:16:16325
VCDS Version: Beta 12.10.3
                Address 2E: Media Player 3       Labels: 5N0-035-342.lbl
Control Module Part Number: 5N0 035 342 E    HW: 5N0 035 342 E
  Component and/or Version: SG EXT.PLAYER H13 0240
           Software Coding: 010000
            Work Shop Code: WSC 00028 02
                      VCID: 295C5
1 Fault Found:
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 0 km
                    Time Indication: 0
« Last Edit: March 22, 2013, 01:22:33 pm by Kiwi »
Offline MarkMarked
« Reply #2 on: March 21, 2013, 11:13:07 pm »
Sounds like the pins are wrong on the AUX connector (the magenta ones in the image)
Double check them, which MDI kit have you fitted (armrest or glovebox)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: March 21, 2013, 11:16:16 pm »
            Work Shop Code: WSC 00028 028 00001
                      VCID: 295C5AD840C6E756F8B
1 Fault Found:
To clear this fault, either code out Aux-in by selecting rear seat entertainment
or add Aux-in (not on the RNS as suggested by the earlier post but to the MDI plug
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 0 km
                    Time Indication: 0
Cluster and Key coding
Location Great Yarmouth
Offline Kiwi
« Reply #4 on: March 22, 2013, 01:21:44 pm »
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 0 km
                    Time Indication: 0
Thanks Eddie,
I did the first option you give me
"either code out Aux-in by selecting rear seat entertainment"
and it worked  :happy2:
