Author Topic: Removing sticky numberplate strips from hell !!!  (Read 3476 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« on: March 21, 2013, 10:34:31 pm »
Well I've been out side for 40 minutes tonight trying to remove numberplate adhesive !
I've had the hair dryer on it, citrus degreeser, APC ( strong Ratios ) and Multiple applications of Tardis ! So far I've removed a 1/4 of the strips
Any suggestions ?
MK7 GTI - ARRIVING DECEMBER
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Removing sticky numberplate strips from hell !!!
« Reply #1 on: March 21, 2013, 10:42:52 pm »
Petrol on a cloth is normally quite good at removing sticky adhesive?
VCDS (Preston, Lancashire)
Offline ell.s
« Reply #2 on: March 21, 2013, 11:27:41 pm »
I used panel wipe on a microfibe cloth and just rubbed it until all the pad had gone. :happy2:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #3 on: March 22, 2013, 10:28:13 am »
Dampen a piece of kitchen roll with tardis around the same size as the numberplate strip and place it over it, leave for about 15 min's and hey presto it will come straight off.
  • -Given: 64
  • -Receive: 48
« Reply #4 on: March 22, 2013, 10:06:44 pm »
Done the Tardis thing mate, the foam on the plate stickers is absorbent so it holds the Tardis quite well, but I did brush it on every 5 minutes and I done a few applications still no luck though !
Credit card to scrape it tomorrow I think !
Offline Andymc7
« Reply #5 on: March 22, 2013, 10:12:24 pm »
I got myself one of these on the recommendation of a friend and was a bit dubious but it worked a treat on my last car  :wink:
http://compare.ebay.co.uk/like/290499908281?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&adtype=pla&crdt=0
  • -Receive: 427
« Reply #6 on: March 22, 2013, 10:15:41 pm »
Im sure i read somewhere, Nail polish remover.  :happy2:
  • -Given: 64
  • -Receive: 48
« Reply #7 on: March 22, 2013, 10:23:24 pm »
Yea actually they are pretty good, the only problem is I was wanting to get it done this weekend, maybe screw fix will do them ?
I might resort to using some petrol I should have some in the bottom of my mk2 golf spare tank.
I've always stuck my plates on previously and I've removed them loads of them but these are absolute f****rs
Tardis usually dissolved them but these are going no where !
« Reply #8 on: March 22, 2013, 10:25:44 pm »
Petrol will do it.  :happy2:
Offline Neil R
« Reply #9 on: March 22, 2013, 10:29:15 pm »
Wire brush?? :scared:
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #10 on: March 22, 2013, 10:34:36 pm »
I'm with Martin - the cheaper the better
Offline s3kel
« Reply #11 on: March 24, 2013, 12:12:17 am »
Try Auto Finesse Oblitarate..
Offline Horatio
  • -Receive: 39
« Reply #12 on: March 24, 2013, 02:08:58 am »
Halfords sell a branded glue/gum remover, Stick stuff Remover. I used this last year on exactly the same job on my mk4 estate and worked really well.
Offline Rob_Quads
« Reply #13 on: March 27, 2013, 08:26:25 pm »
Surprised Tardis has not been able to remove it. Its been able to clean most sticky stuff for us. Might be worth trying to clear off all the sponge just leaving the sticky and using the tardis on that.
Clay bar might also work although never tried it on sticky stuff
Offline thegreatricardo
« Reply #14 on: April 13, 2013, 05:52:28 pm »
+1, I've used this before and it works a treat
