Author Topic: Fuel gauge issue Urgent help please !!!!!!  (Read 1737 times)
Offline Redgtr
« on: March 21, 2013, 11:48:19 pm »
I have a 105bhp 1.9tdi mk5 golf
My fuel gauge doesn't work
So i have replaced the fuel sender ( no change )
Vag com scan ( no faults )
Checked all wires for voltage change while moving sender ( all ok )
Checked sequence on vag com to test the gauge ( works fine )
But I was told that the gauge test is internal and not a test from the sender so I though I will buy some highline clocks
The arrived yesterday,plugged them in and still no fuel gauge :(
I'm extremely frustrated and confused as to what it can be ?
Any advice would be much appreciated
Thank you
Also I'm in Newport South Wales if anyone is local that can help cheers
« Last Edit: March 22, 2013, 01:34:41 pm by Redgtr »
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #1 on: March 22, 2013, 12:31:05 pm »
Free Bump.
Might be worth changing the title to something like "Fuel gauge does not work - Help Please"
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Urgent help please !!!!!!
« Reply #2 on: March 22, 2013, 12:41:38 pm »
As said above, You really need to title threads like this with the actual issue, means someone can search for a solution when they have the same problem as you in future  :happy2:
Offline graeme
« Reply #3 on: March 22, 2013, 01:27:52 pm »
Does the fuel gauge have a separate fuse ?
Offline Redgtr
Re: Fuel gauge issue Urgent help please !!!!!!
« Reply #4 on: March 22, 2013, 01:35:14 pm »
Not that I no of
All fuses are ok :/
Offline Redgtr
« Reply #5 on: March 23, 2013, 11:28:04 pm »
Bump
Anybody???
